1500 RPM with IACV Unplugged
Hey guys, I've been doing a lot of searching around and can't seem to find out why I'm having a weird idle issue. My problem is a low idle bounce in gear after coming to a stop. Initially the car started to stall/die at idle and I changed the distributor and it hasn't died since. I also adjusted the base idle timing to withing spec. The car idles perfectly right at 700 RPMS while in park with lights/heater/ac OFF. But whenever I drive and come to a stop it will idle down to about 500 RPMS, then jumps back up to 700 and idles back down repeatedly. So I initially thought the IACV was dirty, so I cleaned it and the TB with zero luck. I kept reading when you unplug the IACV you should idle at base idle around 450 RPMS. Well mine idles at 1500 RPMS with the IACV unplugged and sounds like its bouncing off redline. I tried to adjust the idle screw, I turned it fully in and fully out and it did not change RPMS at all. So I went to a wrecking yard and found another TB with everything on it, except the MAP sensor. I cleaned it up really good, swapped the MAP sensor onto it and I still have the same issue going on. What could cause the idle to be so high with the IACV unplugged?
I've done the following things, some maintenance and some trying to find the issue;
2000 Civic EX A/T D16Y8 w/ 110k miles
-Timing Belt & Water Pump
-Valve Adjustment
-Plugs, Wires & Distributor
-All Belts
-Air Filter
-Oil Change & Transmission Flush
-Coolant Flush (I made sure it was bled)
-Cleaned TB, IACV
-Replace TB
-Searched for Vacuum leaks
-Valve Adjustment
-All Belts
-Air Filter
-Cleaned TB, IACV
-Replace TB
Re: 1500 RPM with IACV Unplugged
Unplugging the IACV is only applicable to two-wire IACVs. Your automatic EX would have a 3 wire IACV.
False cold readings from the engine coolant temperature sensor will cause the ECU to command a fast idle. Check that cooling system is full. Check ECT sensor with ohmmeter or reading live data by OBDII scanner.
Check the FITV on the thermostat housing for broken plastic or disconnected hoses. Check that you can stall out the engine by blocking the air bypass holes in the side of the throttle body before the throttle plate. It can only idle fast if air is getting in somehow.
My 95 civic does the same and I cant figure it out. When I had bought the car the idle would go up and down like crazy so I replaced the IACV and it fixed the problem. This was in winter and now that its warming up after driving it a little bit the idle will jump up and down at a low idle (450-800) up and down rapidly when I stop. After about a min it will stop and go back to normal. Then it do the same once i stop again.
So far that I’ve seen. It can idle perfectly in park for 20+ minutes.
That explains why unplugging it didn’t work. Thanks for clarifying that. I’ll check the FITV when I get home and try blocking the TB holes.
Let me know if you ever figure it out. Hopefully we can resolve this.
I still have not been able to find anything. What I have noticed is the idle fluctuates with my foot on the brake in drive, here is a video of that;
Here is a video of it in park with perfect idle. I can have my foot on or off the brake and it idles perfect.
Have you set the timing with a timing light? Are there any codes set?
I would try opening up the air screw as much as you can until it starts going too fast in neutral.
Quick update. I’ve re bled the coolant system twice. I’m noticing that even after 20+ minutes and the fan kicking on more than twice I’m still getting bubbles. So I’m leaning towards the air in the coolant system to be my idle surging/bouncing. I’m not noticing any air bubbles until after the fan has kicked on. Or if I rev it up a little bit.
But it the question is, how the airs getting in.
Also when you have an OBDII scanner, watch the ECT reading. On a cold start it should start at about the temperature of the place where the car was parked. Then it should warm up to about 190 and stay steady. Fluctuating readings from the ECT sensor will cause idle speed to fluctuate.
OP invest in a bluetooth OBD2 scanner. Use torque lite app on your phone. Mount your phone up in the windshield and watch the parameters. Engine coolant temp. If its erratic, replace sensor mounted below the distributor, its like 20 bucks and 3 minutes of labor
-I haven't noticed any fluctuations lately, but I did however notice my avg. mpg for last tank was 22. I put some Lucas fuel system cleaner in and did a lot of idling/testing so maybe that's why. Just filled up again so I'll see how this tank does.
-ECT readings have been spot on, slowly will climb to when the fan kicks on at idle and then back down. No jumpy numbers.
-I swapped in my original cleaned throttle body today. I noticed my idle would drop coming to a stop to about 350-450rpm, so I turned the idle screw out a bit like I did with the other throttle body from the junkyard and it seemed to be fine. Idles around 650-700 while in "D" at a stop now. I also checked the TPS Voltage at idle and I was right around .49 which seems close enough to where it should be at. The stock idle screw position was about 1/2 turn out from being turned all the way closed. I had to turn it to 1 1/2 turns out from being turned all the way in to get the idle to not bog down so far. What is the normal position the idle screw should be at?
-Thinking at this point I'll just drive the **** out of it and wait for something to happen?
Took a 200 mile round trip and averaged 34mpg. So no issue there. I am noticing the lights “flickering” slightly. Both interior and exterior while parked and while driving. I tested voltage on battery while off and while running. 12+ Off and 14+ Running. I’m still maybe thinking the alternator could be on it’s way out causing a low idle and light flickering?
Whenever someone with a 6th generation says their lights are flickering, you have to think fuse 15.
Through all of this, no ECU codes and no CEL? Check that your CEL works by turning the key on but don't start.
Is it required to drain the antifreeze from radiator prior to changing this temperature sensor? Thx for your info!
An update to my earlier post - I did flush my antifreeze and then made sure to take all those crazy bubbles off by using a big funnel onto radiator and letting engine warm up as I topped it off. Things came back to normal. Also make sure the IACV is the accurate one - there are 2 kinds: one for automatic transmissions and one for manual. They both look somewhat similar but different mechanism.
90_Si
26
01-22-2008 06:38 PM
turbotime
10-24-2005 12:01 PM
