d16a6 help idle drop car shuts off
Old Aug 10, 2009 | 09:51 AM
bronxhazards's Avatar
Post d16a6 help idle drop car shuts off
hey i have this problem with my engine i just blew the turbo on my d16a6 so i decided to just take my vitara pistons out and put the stock ones in but before i did that the car was running fine but just with a little idle drop when i stop and a lil smoke from the turbo seal and now that i put the stock pistons on i start the car and it idles fine but once it warms up the second i press the gas peddle it starts to die out and then the idle jumps back up and sometime and most of the time it shuts off i did a compression check and i got wierd numbers for 5 cranks like cyl4-235 cyl3-215 cyl2-235 cyl1-220
Old Aug 10, 2009 | 10:12 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: d16a6 help idle drop car shuts off
r u using the same ecu..the tuned ecu?
switch ecus
Old Aug 10, 2009 | 11:03 AM
tuned ecu but it was tuned for without turbo when i was using it
Old Aug 10, 2009 | 11:33 AM
I'm not Rick!
what does your wideband say. try another ecu and see what it does
Old Aug 11, 2009 | 08:02 AM
i dont have a wideband and i just took the engine apart and it had a deep scratch cyl-3 between the sleeve and thewater holes so i brought it to the machine shop to be recut and hesaid that could of been the problembut i wont know till i get it back and put it back together
Old Aug 11, 2009 | 08:15 AM
honda1234567's Avatar
yeap, i also recommend try another ecu
____________________________________
$29 auto insurance for Honda
@ http://www.localdiscountautoinsurance.com/
I guarantee this will help you save a lot of money.
Old Aug 11, 2009 | 06:15 PM
ok i put the head on and it was resurfaced and cleaned machine mechanic said the head is fine now what i noticed is when i press the gas and release it the idle drops like it wants to shut off and all the lights dim and when i give gas again the lights get brighter and also i changed the ecu and same thing happens
Old Aug 12, 2009 | 03:16 PM
i think i fixed the problem i had 2 holes in the hose that connects to the iacv and the thermostat housing
JoelAndrew
Oct 5, 2011 10:07 AM
aeboync
Mar 31, 2008 02:38 AM
derilict
Apr 4, 2007 01:31 PM
JdoggsGSR
Oct 26, 2002 12:06 PM
