What causes b16 to make brown smoke at high rpms?
Old Aug 10, 2009 | 05:08 AM
Lightsped's Avatar
Default What causes b16 to make brown smoke at high rpms?
My b16 with 132k miles on it makes alot of brown smoke at high rpms. The motor is stock and is well maintained. How can I determine if this smoke is something serious or not?
Old Aug 10, 2009 | 06:27 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: What causes b16 to make brown smoke at high rpms?
your car is pooping
run seafoam through it.
check your air fuel ratio sumhow.
rich? piston rings?
Old Aug 10, 2009 | 06:32 AM
Lightsped's Avatar
The smoke is a dark brown/black color. What is Seafoam?
Old Aug 10, 2009 | 06:40 AM
90Rexx's Avatar
search seafoam....
Old Aug 10, 2009 | 06:45 AM
I'm not Rick!
it cleans out your motor and gas tank
Old Aug 10, 2009 | 10:33 AM
Falqon's Avatar
it's going to run a little bit rich at high rpms stock, I know I typically didn't get above 5k more than once every 300 miles so it would be a little black for a few seconds after the crossover.
If it's not more than a "few seconds" of carbon build up you probably should at least start with a compression test and inspect the spark plugs.
Old Aug 10, 2009 | 10:37 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Do a compression/leakdown test.
Old Aug 10, 2009 | 10:57 AM
tw1tch's Avatar
If you're running rich your rear bumper would most likely be covered in black **** above the exhaust
Old Aug 10, 2009 | 12:04 PM
Lightsped's Avatar
Rear bumper is clean. No black stuff on it.....
Old Aug 10, 2009 | 12:06 PM
coryfenton's Avatar
Leaky valve seals.. When your in higher rpm's and your in vtec there is more, higher pressured oil running through. and causes them to leak when they normally wouldnt.. . thats what was wrong with my b16a2. check it out.
Old Aug 11, 2009 | 08:34 AM
Lightsped's Avatar
I thought valve seals only leak if the oil is not changed at correct intervals? Also, aren't leaky valve seals a cause of WHITE smoke? My smoke is black. What is the fix for leaky valve seals? Is it an expensive job laborwise?
Old Aug 11, 2009 | 09:16 AM
Hybrid96EK's Avatar
The seals should be referenced correctly as valve STEM seals. I see too many people calling them just valve seals, which is incorrect. They don't seal the valve, they help to seal the stems.
White smoke is coolant, black smoke is fuel, blue smoke is oil. Valve stem seals will go bad after a while and harden. This will typically first be evident when the car sits for a while and is started. Upon starting it, there will be some blue smoke as it burns the oil that has passed the stem seal and wet the cylinder top.
Old Aug 11, 2009 | 09:21 AM
tw1tch's Avatar
Valve stem seals are notorious to go out in Honda motors. All Hondas burn oil in Vtec, even brand new or freshly rebuilt motors. It's not a huge issue until you start to burn up a lot of oil even during normal driving. I'd advise you to do a compression and leakdown (most important) test.
Old Aug 11, 2009 | 10:14 AM
sde780's Avatar
do NOT use seafoam. you will kill your rings at that high mileage
Old Aug 11, 2009 | 10:44 AM
Hybrid96EK's Avatar
Please explain how seafoam will "kill" your rings.. I want to see if this statement has any form of experience/education behind it or if you are making a bandwagon assumption.
Old Aug 11, 2009 | 01:45 PM
Lightsped's Avatar
I pulled my plugs and installed new ones with new wires. The plugs I pulled look to be the factory plugs from Denso. Wires were dated 1999 as well..... I'll get a pic up tomorrow, but the plugs look pretty good in my opinion....
Old Aug 11, 2009 | 04:09 PM
Hybrid96EK's Avatar
Did you replace them with OEM wires? Can't beat OEM or NGK blues. Anyways, I don't know what would cause a brown smoke. You 100% sure its brown? Never heard of brown smoke. You using oil on the stick? Any signs of coolant loss? If not, I wouldn't worry about it.
Lightsped
Aug 10, 2009 10:01 AM
ek2k
May 25, 2005 01:17 PM
dr juice164
29
Jun 11, 2004 10:40 AM
FLCivic
Feb 19, 2003 07:10 PM
K1 Racing
Apr 8, 2002 02:50 PM
