helpp!!!! B16a2 Swapp What ECU should i use
Old Aug 9, 2009 | 10:25 PM
1.7inurFace's Avatar
Default helpp!!!! B16a2 Swapp What ECU should i use
I got a 98 civic dx what ecu should i use i have a 99 b16a2 swap
Old Aug 9, 2009 | 10:52 PM
JShull's Avatar
Default Re: helpp!!!! B16a2 Swapp What ECU should i use
Easiest way would be to get a chipped P28 or other vtec ecu and an obd1 jumper harness.
If you need to pass emissions a P30-A02 out of a 96-97 del sol VTEC would be perfect and you won't have to deal with the immobilizer stuff from the 99-00 Si ecu.
Old Aug 9, 2009 | 11:03 PM
98civdx's Avatar
Master Detailer
chipped p28
Old Aug 9, 2009 | 11:07 PM
Ruben19's Avatar
my 00 si ecu didn't have the immobilizer stuff.
Old Aug 10, 2009 | 01:25 AM
geneeunit's Avatar
P2T is the 99-00 si ecu.. there is no immobilizer in it..
Old Aug 13, 2009 | 10:15 PM
xxJohnJaixx's Avatar
i have a jdm b16a in my hatch.. and im getting a b16a2 bottom block so i can get my car bar'd. the thing is that my b16a was change to obd1. so if i wanna change the b16a2 block will everything fit according to how it was with the b16a? or i need to swap parts around..
Old Aug 13, 2009 | 10:34 PM
98civdx's Avatar
Master Detailer
yep b16 blocks are basicly the same obd 1 or 2.
the obd doesnt go by the head, or block but the dizzy, starter etc. also the car.
just pull head off install on block and go bar.
Old Aug 13, 2009 | 10:39 PM
jkalex05's Avatar
Not sure what the case is for you, but I have a 96 EX with a 00 B16A2 swap. I use a chipped p28 mapped for a b16a2 with an obd2a to obd1 jumper harness.
Old Aug 14, 2009 | 11:10 PM
Arthas's Avatar
If you want to run the P2T ECU, you will need a OBD2A to OBD2B wire harness. I would rather source a complete EJ8/EM1 harness if I were you.
EcRzFinesT
Oct 29, 2009 04:30 PM
hspoon
Jul 30, 2007 06:47 AM
egdoesit
Oct 24, 2005 10:25 PM
MiguezVTI
Mar 9, 2005 09:52 AM
phantom_sol
May 22, 2003 03:02 PM
