Del Sol rear disk on EG
Old Aug 9, 2009 | 01:44 PM
ImportHatch's Avatar
Default Del Sol rear disk on EG
I have a delsol rear disk I am going to put on my eg. I have the delsol cables, my cx cables and I have 4 dr eg cables. Will anything of these work with my application? Also, would I be needing anything else for this? Rear brake lines? I already have a 3030 prop valve which should work fine.
Also I have the delsol rear sway I'm going to throw on along with my asr subframe brace and omin power LCA's. I have read about some people having problems mounting the GSR sway with the OEM mounting brackets, am I going to have the same problem with the Delsol Brackets? If so, what additional parts will I need? Thank you.
Old Aug 9, 2009 | 02:05 PM
reyracerx's Avatar
Default Re: Del Sol rear disk on EG
you will need integra e-brake cables and thats it. the ones you want wont fit right. everything else youre good.
Old Aug 9, 2009 | 02:06 PM
I've had different people tell me different things. On this post http://www.honda-acura.net/forums/92...onversion.html it says "Since each of the rear disc Hondas have different wheelbases and chassis configurations, go with the e-brake cables for the 92-95 Civic coupe or sedan w/rear discs. 94-01 DC Integra e-brake cables will also work."
I have a set of 4dr EG cables, so this should mean that it should work for me. I think the car I got them off of was drum rear brakes, is the mounting for the cables different? I just want to know someone that has done it first hand before I tear the rear apart.
I was also told I could modify the delsol cables to work, I just need some information from someone that has actually done one of these things. Yes I know I can use integra cables, but I do not have those and would like to use the ones I have if it is possible.
Also still wondering about mounting the del sol sway bar.
Old Aug 9, 2009 | 10:11 PM
Bump
Old Aug 10, 2009 | 10:36 AM
ttt
Old Aug 10, 2009 | 03:00 PM
reyracerx's Avatar
yes you can go for 93-95 civic ex-s coupe or 92-95 ex sedan which came with rear disc. but good luck finding them because both cars are rare to find. specially the 5th gen ex-s coupe.
best next alternative is the integras e-brake cables. they fit perfect and you can find them in any junkyard. im running integra e-brake cable and rear disc myself.
drum e-brake cables wont work.
Old Aug 11, 2009 | 02:56 PM
Thank you, the exact information I was looking for.
So I know that DC brake cables work, but what about DA's? I can snag some DA cables alot easier at the junkyard then DC's.
Old Aug 11, 2009 | 03:24 PM
reyracerx's Avatar
yup! dA's aswell no problem
Old Aug 11, 2009 | 07:29 PM
Thanks a million! I have spent a week trying to see if any cables would work besides the DC's and the si's. I'm gonna snag a few from the junkyard this week.
ScoobyKid
Jun 18, 2010 10:15 AM
RustyE.G.
Suspension & Brakes
Mar 9, 2010 01:56 AM
slide inside
Sep 24, 2009 08:47 AM
Lilk_hdriver
Aug 16, 2006 07:52 PM
