Del Sol rear disk on EG
I have a delsol rear disk I am going to put on my eg. I have the delsol cables, my cx cables and I have 4 dr eg cables. Will anything of these work with my application? Also, would I be needing anything else for this? Rear brake lines? I already have a 3030 prop valve which should work fine.
Also I have the delsol rear sway I'm going to throw on along with my asr subframe brace and omin power LCA's. I have read about some people having problems mounting the GSR sway with the OEM mounting brackets, am I going to have the same problem with the Delsol Brackets? If so, what additional parts will I need? Thank you.
Re: Del Sol rear disk on EG
I have a set of 4dr EG cables, so this should mean that it should work for me. I think the car I got them off of was drum rear brakes, is the mounting for the cables different? I just want to know someone that has done it first hand before I tear the rear apart.
I was also told I could modify the delsol cables to work, I just need some information from someone that has actually done one of these things. Yes I know I can use integra cables, but I do not have those and would like to use the ones I have if it is possible.
Also still wondering about mounting the del sol sway bar.
yes you can go for 93-95 civic ex-s coupe or 92-95 ex sedan which came with rear disc. but good luck finding them because both cars are rare to find. specially the 5th gen ex-s coupe.
best next alternative is the integras e-brake cables. they fit perfect and you can find them in any junkyard. im running integra e-brake cable and rear disc myself.
drum e-brake cables wont work.
slide inside
09-24-2009 08:47 AM
