brake problem
Old Aug 9, 2009 | 12:01 PM
justvisiting's Avatar
New User
Default brake problem
First post. Thanks for having me.
I believe '91 Accord, manual trans.
After driving for a bit, the front brakes lock up. Replaced the left front caliper, thinking that it was the culprit (thought that it was the only one locking up).
I've read maybe master cylinder, booster, or porportioning valve. Is there a way to narrow it down? Car belongs to a young friend who is strapped for cash, and cannot replace all three.
Again, thanks for the help.
Old Aug 9, 2009 | 06:55 PM
nus_dogg's Avatar
Default Re: brake problem
Try replacing the others if you can.
Old Aug 9, 2009 | 07:10 PM
New User
Young one is back from the used parts yard with a proportioning valve and a master cylinder. We'll see.
Thanks for the reply.
Old Aug 9, 2009 | 08:06 PM
nus_dogg's Avatar
Sweet let us know.
Old Aug 16, 2009 | 03:39 PM
P_Adams's Avatar
Make sure there is sufficient free-play at the brake pedal. You should be able to move the pedal at least a 1/4 inch before you feel resistance.
If the pedal can't return to the fully relaxed position, pressure will be retained in the system and the brakes will stay applied, heat up and lock.
In most cases this is caused by the brake switch being kicked out of adjustment or some such foot issue.
P
Old Aug 16, 2009 | 05:35 PM
92civlude's Avatar
P
Welcome back P Adams!
Old Aug 16, 2009 | 11:50 PM
Ed ke6bnl's Avatar
I have herd of internally collapsed brake lines that will hold the calipers closed with pressure ED
Old Aug 17, 2009 | 02:57 AM
Targa250R's Avatar
be professional
This problem is most often caused by an improperly adjusted master cylinder pushrod. As P_Adams suggested, check the pedal freeplay and if needed, adjust the pushrod (which runs from the pedal itself through the booster and actuates the master cylinder piston).
sandjunky
Jul 17, 2010 05:46 AM
LAKER HATER
Oct 22, 2005 01:33 PM
sparknblaze
Feb 17, 2005 09:05 AM
b18punk
Jul 16, 2004 01:45 PM
civicSIracer96
Feb 12, 2004 06:31 AM
