BRAKE LIGHTS
possibly your brake switch which is located at your brake pedal linkage.
check to see if you have power on one wire, and when you apply the brakes, that you have power going through to the other wire.
ok so went outside the switch isnt stuck it comes out when i push the pedal in. i have tail lights and i have license plate lights so the fuses are good what else could cause this
SOMEONE PLEASE
ive looked on other threads and well ive checked all those things
please please please please please please please
SOMEONE PLEASE
What year?
You can't necessarily tell whether the switch is bad by looking at it. If you unplug the switch connector and jump the connector with a wire, do the brakes now turn on? Does the brake light fuse under the hood have battery voltage? Is the black brake light ground wire in the rear broken?
JDM_rolex
Mar 15, 2025 04:50 PM
misha
Dec 5, 2010 06:15 PM
