Replacing power steering pump?
1.Drain the fluid.
2.Disconnect the inlet and return hoses.
3.Loosen the bolts.
4.Remove the belt.
5.Take the bolts out.
6.Remove the pump.
Once reinstalled it will be necesary to bleed it by turning the wheels back and forth a few times.
3.Loosen the bolts.
4.Remove the belt.
6.Remove the pump.
Why does it whine? Are you sure there is enough fluid in there? Are you sure that you put in only Honda Fluid? because other fluids will damage the pumps.
Actually to drain it you remove the upper hose on the reservoir and turn the wheels back and forth a couple times. that gets everything out. Sorry, I should have mentioned that before
murrellington
May 8, 2014 03:30 PM
matmcg
May 21, 2008 12:56 PM
svarver
Feb 25, 2004 09:37 AM
