Tire Wear Problems----NEED SOME HELP
Old Aug 24, 2002 | 11:18 PM
cstoltie's Avatar
Default Tire Wear Problems----NEED SOME HELP
I am having trouble with tire wear on the rear tires(Toyo Proxes FZ4's) of my 97' Civic. I have H&R springs on it. 1.75" drop in the front and 1.5" drop in the rear. I put the Progress camber adustment kit on the front and the shims on the rear because my camber on the car was -2.5 degrees on the rear tires. I was getting unusually fast tire wear on the rear tires only and thought this would correct the problem. I am still getting the tire wear, but it is only every other tread on the inside of my tires in the rear. I can not figure it out. Could my struts be bad or not traveling correctly since I lowered it? I would appreciate some help with this problem.....Thanks
Old Aug 24, 2002 | 11:53 PM
the DR.'s Avatar
Default Re: Tire Wear Problems----NEED SOME HELP (cstoltie)
every other tread..? if you looked at it side ways would it look like this.. |\|\|\
crude drawing but i hope you figure it out. sounds to me like a toe problem
Old Aug 25, 2002 | 12:33 AM
MR. ARIZONA's Avatar
Default Re: Tire Wear Problems----NEED SOME HELP (CIVICtypeS)
uh......yes i would say you have a problem....
Old Aug 25, 2002 | 09:49 AM
wessieball's Avatar
Default Re: Tire Wear Problems----NEED SOME HELP (QUICKTEG)
I've had the same problem. It's definitely a toe problem. It's either too much in or out so it's causing the tire to "drag" slightly across the road. I've had this problem for quite a while. The last alignment I had corrected it slightly.
Old Aug 25, 2002 | 11:11 AM
cstoltie's Avatar
It is along the lines of the drawing. My reaadings for the toe on my last alignment were within Honda specs..looks like i need to have it looked at by someone that specializes in suspension work and not the Honda dealership...
Old Aug 25, 2002 | 11:18 AM
1 2 NV's Avatar
tire wear will continue once it has started, u need to rotate ur tires every 5k miles too.
Old Aug 25, 2002 | 02:46 PM
wessieball's Avatar
Default Re: Tire Wear Problems----NEED SOME HELP (hondaatwsu)
hondaatwsu is right. Once you've started with bad tire wear, it's hard to correct it. Do you check the pressure often? My last set of tires wore out really quick because they had a tendency to lose pressure rather quickly. I didn't know this until it was too late. When your tire pressure is low and your camber is more negative than usual, you'll find that the tire's "foot" is riding a lot more on the inside corner of the tire.
Now with the new set of tires, I make sure that my pressure is well above Honda's suggestion (low profile tires can take more pressure) which is around 40 psi. This set has worn a lot better than the old set and will probably last me 3 (or more) complete summers.
ohboitony
May 15, 2010 04:43 PM
TurboEM1
Aug 28, 2006 11:30 AM
01_prelude
Jun 20, 2006 06:05 AM
UKpyro13
Nov 15, 2004 07:34 AM
cstoltie
Aug 24, 2002 11:09 PM
