99 si won't pass 6k
I have a 99 civic si(b16a2) Turbo running 10 psi. I have a apexi vafc and rc 320cc injectors.
The car runs great intill it gets around 6k, it just misses cuts out. it will not go past 6k.
any ideas?
any ideas?
Your ECU is running in Limp Mode. It does that when things go bad.
It helps protect the motor from cheap n00bs that like to boost motors without a proper tune.
You can try disconnecting the battery for 15 minutes and see if it runs in limp mode again. What Check engine lights are you getting?
b18c99si
Aug 23, 2012 03:42 PM
