Cap,rotor Problem
i just changed my cap and rotor in my car,i start the car,drive for 5 minutes and then it stalls,i try to start again...nothing,i get the car towed at home put back the old cap and rotor on...nothing,what can the problem be?i installed the wires properly.please help me
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
check your firing order.
Are you ABSOLUTELY sure you put the wires back on in the same order?
EDIT:
EG/EK distributors are notorious for just dying. I had one go out on me in a similar fashion at one point. Now I'm not saying that's what it is, just something to consider. I'm assuming you don't have a spark plug wire tester?
EDIT:
No to which question? Not having a wire tester or putting the leads back in the correct order?
On second thought, if you had put the wires back in the wrong order the car wouldn't have started. I think you may have a dead dizzy.
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
This is exactly what happened to me in April and the car is still dead. I had a couple of threads about this on April 21 or 22 under "98 Civic died suddenly". You can search to read those.
Just like you, I had just put NGK plugs, Tec cap and rotor and I think Prestone wires all purchased online from a Honda dealer. I started it twice with no problem. When I went to drive it I got about 1000 feet and it shut down without a single sputter. It just shut off! I got it pulled home, put on the old stuff and still nothing. I have a thread today about it! It is "98 Civic EX AT onlly 82K..." if you want to read what some folks offered trying to help me.
I had immediately ruled out the timing belt. Everything else works in the car as far as I can tell. The coil and ICM tested good at Autozone. good luck
crxaddikt
11
Jul 25, 2013 11:57 AM
Chrisbequick
Oct 16, 2008 07:39 PM
Kentagious
Jan 17, 2007 11:40 AM
S2KILLA
Nov 29, 2006 06:00 AM
