where do i hook up the map sensor and tps on the my b16a.
i have a 91 crx si w/b16a, i have a itr trottle body, i dont know where to hook up the map sensor, or the tps, do i hook it up to the firewall or to the itr trottle body. thanks
Are you saying to splice the one from the firewall and extend it to the new TB? Or run a new map from the ecu? Just wondering, as I have mine running on the old map, thanks.
1st hybird, where did you hook up yours to. to the firewall or the trottle body. which way is the rite way. thanks
use the MAP sensor located on the ITR TB.. its way better than the vacum one on the firewall..... and yes use the TPS off the ITR.........
B16powwer : Yeah I have mine running on the firewall right now, but I might do what F=Wt says and run it to the new TB. Cause mine is running kind of rough right now, I also think my timong is a bit off.
F=WT: Thanks for the tip
thank you all for your responds, i tryed hooking it up to the itr tb. but the car wont turn on. if i hook it up to the firewall, it runs prefect.
gsxr1k05
Jan 15, 2007 12:58 PM
