Wiring problem somewhere - need some help.
Old Aug 7, 2009 | 11:16 AM
CRJenkins13's Avatar
Default Wiring problem somewhere - need some help.
Hi. For starters, I tried to search, but I don't really know how to word my problem without explaining it in detail...so my results were kind of vague. Secondly, I installed mobile audio and have a bit of experience, but not enough for bragging rights, and I've been out of it for ~ a year. So when explaining / helping me, take into account I'm not a naive 16 year old installing his first subs
I recently began my install on the following items:
Pioneer 7700 mp (old, I know)
Kicker 750.1
Kicker 340.4
Kicker RS652 components (front and rear)
Ok, so now for the problem. I installed everything but the rear speakers and it worked, but I've had some wiring issues behind the radio off and on the entire time. For one, I had whining noise. I've a couple basic checks, and still haven't figured it out...grounds are good, wires ran on opp sides of the car, and none of the wiring / RCA's was cheap, and bought brand new. Second, to be blunt, my mids / highs suck. I only have my fronts in, but I've heard plenty of cars with 1 and 2 speakers in it, not amplified, on shitty speakers, and they are louder / more clear than my speakers. All of this equipment was in its original packaging for about a year under my bed, but nothing is damaged that I can tell. Any suggestion on my volume loss? - This is why I explained I worked in the industry for a bit. I don't want to sound like some kid that wants his **** "bangin", I'm legitametely not getting quality sound.
Thanks for the time
Old Aug 7, 2009 | 01:14 PM
twentyhurtz's Avatar
Default Re: Wiring problem somewhere - need some help.
ok for the Noise - did you use factory hu ground? RCA's - are these new? old?
Try a new ground location, maybe your currently used ground location is not suitable.
Are you using an electronic xover/eq?
Not enough volume - i know these question may seem insulting, but we all make mistakes, its usually the simple ones that get us.
Did you adjust the gain yet?
are you crossovers set correctly ( hu and amp)?
is there a "loud" feature on this hu? i haven't installed a 7700mp in like 4 years and don't remember.
Old Aug 7, 2009 | 01:33 PM
nsxxtreme's Avatar
your whining noise is a ground loop. You have a bad ground somewhere.
Old Aug 7, 2009 | 11:30 PM
8520's Avatar
What did you plug in first on the hu? The rca's or the power/speaker harness?
Old Aug 8, 2009 | 07:23 AM
Yes on the factory head unit ground, I could easily reground that. The RCA's are new, and the only equilizer I'm using is in the radio. My gain / crossovers are set correctly, and yes, there's a "loud" feature on the head unit. And it's on. And No worries, I make some pretty dumb mistakes so nothing can be insulting when there's a possibility that's what's wrong.
Hmm...I used to always plug in harness then RCA's, but since I was doing 3 pair, maybe I plugged those in first to ensure they were in the right spot. Is there a right / wrong way to do this?
Thanks
Old Aug 8, 2009 | 08:28 AM
dj-t's Avatar
maybe the grounds for the rca are bad on the head unit try grounding the rca with a separate wire to a good ground source.
unplug everything and use a meter to check the ohms on the ground use one lead to the rca output ground and the other lead to the radio chassis see how much resistance it has.
viewsonic111
Sep 13, 2010 09:31 AM
Shikaido2004
Apr 15, 2008 12:54 AM
envision
Dec 2, 2007 07:22 PM
abercrombemonkey
Nov 4, 2005 01:09 PM
n0 iNTegRiTY
Audio / Security / Video
Jun 30, 2003 02:59 PM
