Fresh head & block surfaces, new HG, leaking?
Old Aug 7, 2009 | 09:42 AM
JDM_SOHC's Avatar
Default Fresh head & block surfaces, new HG, leaking?
So i get everything put back together finally on my Z6... and now im leaking coolant from under the distributor... It wasnt even leaking before i had the head machined, it was just boiling the coolant, so now im stuck saying wtf..!! I torqued everything to spec "torque wrench started actin screwy on head bolts #8 #9 & #10" but seemed to work fine.. Could improperly torqued bolts cause this..??
Old Aug 7, 2009 | 09:48 AM
1992Si's Avatar
Default Re: Fresh head & block surfaces, new HG, leaking?
Sounds like a torquing problem.
First off bolts 8,9 & 10 are at different ends of the head.
Did you step torque or just go to 53ftlbs?
OEM bolts or ARP studs ?
Your going to get lots of questions.
Did you clean the threads out on the block before you installed the bolts/studs ?
Old Aug 7, 2009 | 10:00 AM
JDM_SOHC's Avatar
I kno bolts 8, 9, and 10 are on different ends, but what i meant was bolts 1-7 torqued fine, than once i started torquing #8 my torque wrench wouldnt click to let me kno when i was there..
yes i torqued in 3 steps, i believe it was 15, 30, 53...
OEM Bolts...
And yes i cleaned the threads out to the best of my ability...
I'm also thinking its a tq problem, maybe i should take'm out and try again..?
Old Aug 7, 2009 | 10:07 AM
1992Si's Avatar
No,
Just tighten them (equal) with a 1/2 ratchet, then go get a better torque wrench. Do not loosen them.
I have noticed the last few on SOHC's will feel funny, set the wrench at 50ftlb and torque all in the order until none move. then go to 53ftlbs do the same, in the patteren until none move.
Old Aug 7, 2009 | 10:10 AM
JDM_SOHC's Avatar
starting from the center and working my way out just like i did when i installed'm..??
Old Aug 7, 2009 | 10:11 AM
1992Si's Avatar
See my edit, I added
Always follow the pattern
Old Aug 7, 2009 | 10:15 AM
JDM_SOHC's Avatar
yeah exactly, they almost feel more snug than the rest...??
Old Aug 7, 2009 | 10:19 AM
1992Si's Avatar
I have gone around 5 or 6 times before they stopped moving.
Old Aug 7, 2009 | 10:20 AM
delsolproblems's Avatar
Under the distributor is the thermostat housing. You sure that's not leaking?
Old Aug 7, 2009 | 10:24 AM
1992Si's Avatar
Good thought, check the water outlet neck too.
Old Aug 7, 2009 | 11:05 AM
JDM_SOHC's Avatar
yup i put my tq wrench on 53lb's and just went over'm about 3-4 times and WALLAAAAAAAAAAAHHH..!!!!!!!!!!!!!!!!
ur the man no leaks, no drips, no nothing but madddd VTAKKKKKKKK..!!! thanks a lot bro i appreciate it...
Old Aug 7, 2009 | 11:06 AM
96 EX's Avatar
I'd check under the distributor as well for a little hose. Mine recently crumbled and was leaking, got a quick replacement and it was fixed.
Edit: Nevermind seen you already fixed the problem.
Old Aug 7, 2009 | 11:09 AM
JDM_SOHC's Avatar
its cool, thanks for the input anyways bro.. "and also thanx for havin my old avatar, always brings a couple laughs"
Old Aug 7, 2009 | 11:25 AM
1992Si's Avatar
Glad it worked out for you.
In about 10 day's you'll want to set the wrench at 53ftlbs and tighten them all again. Then may be one more time before winter.
Tighten only, do not loosen.
Old Aug 7, 2009 | 11:59 AM
JDM_SOHC's Avatar
yeah i was readin that somewhere else also, but was kinda skeptical... thanks for the reassurance bro...
hYbRid_Eg6
Jan 26, 2012 10:00 PM
The93egg
Mar 1, 2009 11:02 AM
lrayford
Jan 19, 2009 04:33 PM
WishinItWas
Aug 23, 2007 07:23 PM
oranginal
May 2, 2006 11:14 AM
