OBD0-OBD1, making my own harnesses?
I have a Z6 that I am putting in my CRX... I need to know of all the harnesses I will need.
I know I need these ones...
1) ECU Jumper, made from obd0 ecu female plugs and obd1 male plugs.
2) Distributor harness, made of male obd1 plugs and female obd0 plugs (?)
3) o2 4 wire harness... I am not sure of how to wire this up, or how to make the harness.
4) VTEC sub-harness.
with #3, where do these wires come from? Do they connect to somewhere in the EF wiring harness?
#4, I have to run them all the way from the VTEC solenoid to the ECU.
Someone correct me on where I am wrong please. I don't want to pull my engine until I can make these harnesses, and until I know everything I need to know.
is there a guide for making a harness though?
has in how to
de-pin and pin wires http://www.fourthgenhatch.net/depin.html
solder and heat shrink prety self explanatory practice makes perfect.
this is all in faq but since i feel nice to you i will link you to it
1.https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d-i-y-faq-obd-0-obd-1-pinouts-conversion-help-1319235/ and or
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/non-obd-obd1-conversion-gold-ef-1510399/
2.https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/obd0-obd1-distributor-wiring-1349052/
or buy one from a member on here crx-sir
3.for the o2 find a obd1 clip both male and femal depin the one that goes to the ecu and pin wire in it hook up directly to ecu
and 4. somewhere in faq
carlosjdmcivic
Jul 11, 2012 01:56 PM
