Need info for obd2 b18b1 swap to a 99-00 ex
i want this swap but i can't find a parts list or a guide for this swap. I've search everywhere and i only found b20 swap list. Can anybody give me a parts list for my car..
Here some info:
2000 ex auto-manual conversion.
obd2 ls engine
b16a2 transmission
dont know what ecu i will use?
what wiring harness should i buy?
what brackets i need?
i have a tanabe exhaust in my car. will this fit on the ls header?
it's going to be a daily and smog legal in texas
If you find any swap guide please paste it here..
Thanks...
Here some info:
obd2 ls engine
b16a2 transmission
Thanks...
ecu can be from any obd2b 98-01 integra ls engine. So usdm p74?? Not sure if they have immobilizer units in it or not so it may or may not be usable since you want to stay legal.
Wiring harness must be from a 99-00 civic or obd2b. I would prefer any manual 99-00 civic ex because there are no modifications to be done. Or you can simply reuse your original engine harness and do the modifications.
The brackets you need are the 99-00 civic SI rear engine bracket and the 99-00 civic SI driver side post brackets for your motor mounts.
Most swaps will require some sort of header modification. Lets see if you get lucky with the exhaust system you have now. If not then you need to take it to the exhaust shop. If I remember, the GSR or maybe LS header from the integra will fit perfectly if you remove the cat converter in between. So catless
killakalipoph
Mar 14, 2009 07:16 PM
SiB16A
11
Sep 27, 2005 07:00 PM
GoodGasMileage
Jun 30, 2003 11:56 AM
