What engine harness can i use?
Old Aug 4, 2009 | 11:01 PM
Enjoibaker's Avatar
Default What engine harness can i use?
I have a 97 civic ex im doing a auto-manual swap. What engine harness can i use? Do i have to use a 96-98 ex harness or can i use any obd2 harness from 92-95 and 96-98 v-tec or non v-tec as long as its a 5spd one?
Old Aug 4, 2009 | 11:27 PM
raidacaipo's Avatar
Default Re: What engine harness can i use?
I would find a usdm 96-98 ex manual harness.. theres no such thing as a obd2 harness from a 92-95. And no you cant use one from a 92-95 civic. You can use any 96-98 engine harness as long as you decide to do the modifications to it and as long as its manual. The best harness to use is your original engine harness. You can just modify it.. Im not sure if you can still use the auto harness though.. someone correct me
Old Aug 5, 2009 | 12:57 AM
H22a_bubbleback's Avatar
Yes you can use your stock harness you will most likley have to change around some pins and or remove some. But it's all relativley easy to do. Get the wiring diagrams for both the AT and the MT chassis and go from there. It's not as hard as you would think. Wiring scares people when it's not as bad as one might think.
Old Aug 5, 2009 | 01:06 AM
raidacaipo's Avatar
yup.. I actually learned a great deal after modifying my stock non vtec harness.. I learned all the sensor plugs and everything! and I can brag about it :p
Old Aug 5, 2009 | 10:43 AM
Enjoibaker's Avatar
Thanks for the help. I just bought a 97 ex one for $85 at a local junk yard. Which it thought wasnt to bad. Now i dont have to fool around with the wiring.
CodyGt3076r
19
Sep 27, 2012 12:53 PM
SIR_APPROVED
Dec 18, 2009 06:59 PM
endlessdv
Feb 6, 2005 04:16 PM
seerxsi
May 10, 2004 06:07 PM
who00knows
16
Sep 23, 2002 08:15 AM
