b series swap sensor info
Old Aug 4, 2009 | 08:05 PM
0ne-Cam's Avatar
Default b series swap sensor info
im sure this has been asked before, but i been searching and trying to figure out what sensors on the block do i need. its a obd1 b18a1, i know there is 2 sensors in the back of the block, oil sending unit and 2 wire plug for coolant? there is a water temp sensor on the left side of head, right under the dizzy. what other plugs will be needed for the swap to run correctly without throwing any codes
Old Aug 5, 2009 | 04:33 AM
dephtone's Avatar
Default Re: b series swap sensor info
The 2 wire plug on the back of the LS block is the fan switch.
Everything should plug right up to the LS block from your current harness, except for your 1 wire o2 sensor that runs by the tranny and the emissions stuff thats on the firewall.
ef dino
May 14, 2008 11:58 PM
self_made
Apr 30, 2005 10:05 PM
scrubachu
Apr 4, 2005 02:42 PM
D-Man
Nov 28, 2001 12:56 PM
