Low idle then death issue
Old Aug 4, 2009 | 05:24 PM
jawsiiv's Avatar
Default Low idle then death issue
93 Civic Si Manual.
Before rebuild engine decides to die. Loss of power and bogging, but no low idle
Find out that the head blew like 2 valves in 2 different cylinders.
Replace the entire engine, newer head.
Car now boggs and does not idle, it dies
Intake is from previous engine, and is it possible that the IACV went when I changed the engine and cleaned the IACV????
Thanks.
Also no CEL, good ECU.
Old Aug 4, 2009 | 05:31 PM
-__-'s Avatar
Default Re: Low idle then death issue
same problem check my thread lol
Old Aug 4, 2009 | 07:43 PM
Former User's Avatar
Originally Posted by jawsiiv
93 Civic Si Manual.
Thanks.
Does the engine also rev poorly and misfire or is the problem solely with a low idle? Do you have a FITV on the throttle body? If so, clean it and the IACV.
Old Aug 5, 2009 | 04:27 AM
jawsiiv's Avatar
It does have a FITV, but does not misfire. It just rev horribly. I cleaned the FITV when I took the Intake off, and I cleaned the IACV. Could they possibly be bad? Also will a D15Z1 IACV fit on a D16B7 throttle Body?
Old Aug 5, 2009 | 06:55 AM
Inspect the plugs, wires, cap, and rotor and check the ignition timing.
Old Aug 5, 2009 | 07:53 AM
biggdogg's Avatar
did you swap the map sensor and tps harness plugs. they will plug into each other.
Old Aug 5, 2009 | 06:32 PM
jawsiiv's Avatar
Naw I got them in the right one. I changed MAP nothing happened. I loosen the IDLE screw and it idles better, yet still there is a loss of power. Could it be a bent valve???
Old Aug 5, 2009 | 06:47 PM
Check the ignition components and the ignition timing.
Here's the right way to adjust the idle speed:
Old Aug 7, 2009 | 04:55 PM
jawsiiv's Avatar
Tried that and the Idle is set correctly. I believe that I have blown the head gasket, because I am eating coolant, and it is overheating after driving it for awhile. although it is not smoking out the exhaust. I hope that changing the head gasket will do the job.
Nic0807
Honda Civic (2001 - 2005)
Dec 4, 2018 08:50 AM
EK45VTi
Dec 11, 2007 06:46 PM
Import Prelude
Jun 22, 2007 05:52 AM
ic89
Oct 14, 2006 02:51 PM
sr20seth
May 31, 2003 08:24 AM
