Will a turbo kit from a Civic SI bolt onto an Integra LS?
I'm taking a guess that the downpipe and intake piping will have to be modified.
It'll fit with minor modifications like the final charge pipe. The intake pipe on the turbo might need to be modified too. I think the downpipe should line up fine but you'll have to add piping anyhow if its a bare kit like drag3.
Rob
i think the piping should all be the same...just the downpipe may be too long or too short(not sure which). But u can just get that part welded.
I think that the deck height on the LS may be a little taller, so i think that you may have to make some modifications to it
Rob
Rob
actually a few friends and I are using drag downpipes from gsr kits on their b16's and they clear just as well as the Si kit's downpipe does.
