turbo kit from a 99ls fit on a 2000si
Re: turbo kit from a 99ls fit on a 2000si (dumpeDc2)
Chances are is that the whole kit will not be bolt on (manifold will be). You'll probably have to mess with the intercooler piping and downpipe.
I'm a Jackass
Re: turbo kit from a 99ls fit on a 2000si (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">yup the b16 block is a bit shorter so the dp might have to be modified</TD></TR></TABLE>
if it is shorter wouldent it hove more room for clearince
I guess I will just try it out and do what is needed
downpipe should work fine, it's the upper charge piping that'll probably have to be modified.
btw, i have a 96 ls and my friend has the 00 si, and we are running pretty much the same setup, just my charge pipe is different from his.
99ls
08-25-2002 05:17 AM
