bore tb question
Old Aug 24, 2002 | 03:46 PM
spork sport's Avatar
Default bore tb question
what's the difference between boreing out your stock tb n buying a bored tb from an aftermarket company say JG or spoon or wutever?
of course both will have same size
[Modified by 1.6se, 12:46 AM 8/25/2002]
Old Aug 24, 2002 | 05:32 PM
94civicx's Avatar
New User
Default Re: bore tb question (1.6se)
some people prefer to buy an aftermarket one so they can go back to stock if needed really. If you had it bored properly to the same specs as say the jg or spoon then it will flow very similiar if not exactly the same
Old Aug 24, 2002 | 05:48 PM
Unsung's Avatar
my buddy bored his... didn't work afterwards... totally irradic idle... the metal shavings get everywhere and have a tendancy to mess up sensors.
Old Aug 24, 2002 | 07:01 PM
bluedelsol's Avatar
dont bore it yourself, have a machine shop do it, we had a v8 bored out .30 over for our 1979 jeep cj5 and it runs great, just like new, should be fine on a 4 cylinder to, didnt cost that much, i will probly have it done to my del sol when i do my mini me swap!
Old Aug 25, 2002 | 12:21 AM
yes it will be done by a professional n also comes with a new throttle plate
so what's the diff between that n an aftermarket?
other than it cost 100-200 dollars more
Old Aug 25, 2002 | 11:15 AM
rocket_R's Avatar
i got a type R throttle, how much should i bore it out to for an all motor setup?
Old Sep 3, 2002 | 03:53 PM
MisterB's Avatar
Default Re: bore tb question (rocket_R)
where can you get a new throttle plate can you just get an itr from acura if i want to bore 58mm b16 tb to 62mm like the itr or would i have to get a costome plate... sorry sort of newbe q
user 9782082308
10
Jan 25, 2003 11:41 PM
tuco_ruiz
Oct 30, 2002 07:16 PM
CRVRX
Sep 10, 2002 07:12 AM
rolow
Sep 4, 2002 06:19 AM
ic108
Nov 22, 2001 06:55 AM
