I have Spoon TB should I get Ericks 70mm TB?
I have a Spoon TB on my B20 vtec with ITR IM should I get an Ericks 70mm TB?
I know where I can still get a new one.
Do you consider this an upgrade?
Re: I have Spoon TB should I get Ericks 70mm TB? (rolow)
erick tells most ppl they don't need the 70-68 tb they usually just need the 68-66 unless it's fully built
I agree. Unless you have a significant amount of work done(12.5:1 compression,big cams,head work) the Spoon t.b. should do just fine. You would even be fine with a stock ITR t.b. "Bigger is better" is not the best motto to use when building an all motor Honda
