Gauge Cluster Dies?
Im driving earlier, and all the gauges on my cluster go out- temp/tach/speedo/fuel- none of the needles are moving- but my turn signals and other lights work.
did some searching, read to check if my head lights/brake lights are working it wouldn't be the fuse- checked it and replaced it anyways.
removed my cluster to check the wiring in the back- no cuts, nothing physically wrong with anything back there- un-clipped everything to make sure the contacts were fine as well, and they were.
other then the fuse- and the wiring behind the cluster, what are some other things I should look for- im trying to get someone local with a spare integra cluster i could try out- but im guessing since my turn signal lights and all that other stuff work- the problem is electrical and not with the actual gauge cluster right?
catsman50
15
Aug 1, 2011 11:57 AM
jdmeg6hatchy
14
Apr 22, 2009 06:24 PM
