clocking the middle of the turbo???
Old Aug 24, 2002 | 02:41 PM
B18C-RnVA's Avatar
New User
Default clocking the middle of the turbo???
i have a t3 60-1 which is water cooled and oil fed. my turbo has the water feed and return north and south and the oil feed and return east west. i was wondering how do you clock the middle section so i can make it the oppostie...oil feed and return running north south and the water cool section running east west. I already clocked the compressor side. also on the turbo it has 4 bolts on the middle housing section.....
[Modified by B18C-RnVA, 11:44 PM 8/24/2002]
Old Aug 24, 2002 | 02:45 PM
B18C-RnVA's Avatar
New User
Default Re: clocking the middle of the turbo??? (B18C-RnVA)
also, could you guys give me any links to shaving the block for my 60-1 t3, so it will fit?? i tried searching but couldnt pull up what i was looking for. thanks
Old Aug 24, 2002 | 04:07 PM
B18C-RnVA's Avatar
New User
help please, trying to put on this boost today.
Old Aug 24, 2002 | 07:03 PM
92gs-r's Avatar
unbolt the compressor side and the turbine side. i had to put mine in a vise and bing on it with a hammer to rotate to turbine side. it worked tough...
Old Aug 24, 2002 | 07:40 PM
rjardy's Avatar
Just get in there with a die-grinder and trim the webbing, its not that hard. If you need pics or anything feel free to im me
Rob
Old Aug 25, 2002 | 06:51 AM
B18C-RnVA's Avatar
New User
Default Re: clocking the middle of the turbo??? (rjardy)
unbolt both sides...whats a vise??
Old Aug 25, 2002 | 07:10 AM
AB16A2T's Avatar
That is a vise.
Old Aug 25, 2002 | 09:35 AM
ion_four's Avatar
Default Re: clocking the middle of the turbo??? (AresB18BTurbo)
damn, bitch! That's a vice! if you want to know where to grind your block you'd have to let someone know what kind of manifold you're using, but the best way is to try and fit it all together...grind a bit, then repeat as necessary. I had to grind a good bit and it's still jacked, because when I torqued it down with the intake pipe on, it hit and I have an exhaust leak=slow spooling.
Old Aug 25, 2002 | 11:57 AM
B18C-RnVA's Avatar
New User
Default Re: clocking the middle of the turbo??? (ion_four)
yeah im using a drag3 manifold and a t3 60-1 turbo. we tried to fit it, but the compressor housing is hitting the webbing on the block. anyone tried using a dremmel to shave the webbing on the block or is that a bad idea.
Old Aug 25, 2002 | 12:19 PM
Cwest EK's Avatar
i used a dremel with some cut-off wheels..it worked perfectly fine but it took a lil while
Old Aug 25, 2002 | 01:35 PM
B18C-RnVA's Avatar
New User
Default Re: clocking the middle of the turbo??? (Cwest EK)
any certain wheel i should get to use on the webbing
mrx
May 9, 2005 05:31 AM
TABIAS
Mar 16, 2004 02:52 PM
B18C-RnVA
Aug 20, 2002 10:35 PM
inspyral
Jul 25, 2002 10:12 PM
B18C-RnVA
May 10, 2002 12:51 PM
