turbo D16y8 build need advice
Old Aug 3, 2009 | 08:11 PM
shveazzy's Avatar
New User
Icon6 turbo D16y8 build need advice
Hey so im geting ready to buildup my block so that i can put a turbo on it. I would like to get some where around 300hp out of it. Im just wondering if i will need to do anything other than buy pistons and rods if im gona put 15psi of boost to it. Im a noob but my dads been working on cars for 40 years. I guess im looking for an un-bias oppinion and advise for this build. also if i do succefully get 300hp out of this what am i gona need to do to the drivetrain so that i dont destroy every thing.
any knowledgeable advise please
Old Aug 3, 2009 | 09:19 PM
1meanassbitch's Avatar
Default Re: turbo D16y8 build need advice
well arp head studs will be a plus
Old Aug 3, 2009 | 09:25 PM
Blu_EF's Avatar
Hey best of luck, im planning on pushin 300 to 350 with 10 to 20 lbs of boost on a z6. Good rods and pistons will help you, and like^ said, use good studs. Are you doing and head work?
Old Aug 3, 2009 | 09:31 PM
dohcdelsol's Avatar
get low compression pistons, CP's or Vitares
beefy rods, eagles or manlys
ACL bearings
depending on condition of engine, id recommend resleaving but it isnt necessary.
def arp headstuds as the oem headbolts tend to let the head lift up under load.
then you wil need atleast 440cc injectors
fuel pump
and a very good tune
id recommend a new clutch kit from exedy or act but the stock transmission should hold up find pending how you drive. maybe look into an lsd down the road.
you have alot of research to do and learn before you buy anything. personally id invest in a nice brake system upgrade, doesnt have to be a kit, and much stiffer suspension and tires. no point to having power if you cant put it to the ground.
Old Aug 4, 2009 | 12:09 AM
ke98248's Avatar
You need a an aftermarket clutch capable of holding far more power than your stock one, I'd go with LSD motorsports or similar, one capable holding 250-285ft/lbs of torque. Also need to get your stock flywheel resurfaced.
Need lower compression piston/rod combo, hone and balance block, 550CC injectors, a 255lph walbro fuel pump, ARP head studs, and a traction bar you'll have lots of wheel hop. It would be smart to get a boost and oil pressure gauge (digital) as well.
Optimally you'd also get a Quiafe LSD setup for your tranny, but that's quite pricey.
Get a good street tune from a reputable tuner (very important)
Old Aug 4, 2009 | 04:42 AM
SOHCannon's Avatar
Suspension is a must with 300whp... And dont cheap out on the tune.
Old Aug 4, 2009 | 02:30 PM
ballisticej1's Avatar
do some head work and that 300hp goal will be easier to attain.
Old Aug 4, 2009 | 05:14 PM
shveazzy's Avatar
New User
What should i do the the head. Just an aftermarket cam or port and polish or what? I really don't know what to expect or what i need to do to get the horsepower i want. What kind of head work should i get done? I figured i would leave the head stock because were gonna throw a turbo on it.
So far all i have considered is
SRP pistons 9.1:1 450.00
Eagle H-beams 350.00
ARP head studs 100.00
For the engine block itself.
I figure ill just piece together a turbo kit myself. i don't want to buy one. One of the bundled kits you find online.
What else do you guys think i need to get 300 HP out of this engine besides just the turbo kit? What kind of head work if i need it?
My Dad picked up a lightweight flywheel and aftermarket clutch. The car this is going in to is a 97 civic 3door that used to be home to a turbo'd b18c1 at one point. the guy i bought the car from kept the engine but other than that its in pretty good good condition. no scratches on the paint, interiors intact, its been lowered with coil overs, and has mirror tinted windows.
Old Aug 4, 2009 | 05:57 PM
padme's Avatar
omg..so much more....
Cooling system gotta go...
mishimoto kit or like(fan hoses)$300
new mounts $350 or so
new intake $300 or so maybe less
new vac lines a +
$200-300 on new headgasket/belts hoses bolts
prob a new steering wheel for looks u know...
Old Aug 4, 2009 | 07:37 PM
shveazzy's Avatar
New User
new vac lines a +
most of that kinda stuff my pops can get.I need to get a nice radiator though for sure. What needs to be done to the head and will the stock crankshaft be able to handle 300hp if i can achieve it. Why would i need a new intake manifold? And the guy who had the car b4 left the interior in pretty good condition so im not going to spend any money inside it
Old Aug 4, 2009 | 07:41 PM
Just get a cam for the head, and port n polish.
Old Aug 5, 2009 | 01:59 PM
dohcdelsol's Avatar
its not necessary to pnp the head. if you upgrade the cam, the specs are gunna tell you to upgrade the valves n springs also.
i went with a zex59300 cam for my z6 and upgraded to crower valves/springs/retainers and milled the head. can easily break 300whp wo worrying about air flow rate.
dnt forget restrictive exhaust piping and IC piping will also limit power.
Old Aug 5, 2009 | 05:23 PM
shveazzy's Avatar
New User
thanks man
Old Aug 5, 2009 | 05:44 PM
dohcdelsol's Avatar
and depending on where you are located, im on the east coast, i had Dave at Headgames build my head and Dan at FirstStateMotorsports build my block. both awesome guys to deal with did an awesome job. highly recommended.
Old Aug 5, 2009 | 06:39 PM
95civhb's Avatar
so you're putting 15psi to make this power goal....
put up a post like that in the FI forum and you'd get chewed to pieces...
just a tip... the power you will achieve on 15psi varies widely depending on the turbo selected...
do some more reading in the FI forum, and see what other guys are running... if you have the money, a gt28 series provides a nice powerband and won't choke out up top...
good luck...
Jay4dnb
10
Nov 4, 2009 08:44 PM
Maines_Cleanest00
May 28, 2009 04:55 AM
civic_saints1
Jun 10, 2007 02:09 PM
slownsteadygetsunowhere
Apr 5, 2005 12:24 PM
SilverCivic2287
Nov 14, 2004 04:35 PM
