window rolling up alittle slow. how do i lube the window tracks?
Old Aug 24, 2002 | 01:51 PM
Ch33se's Avatar
New User
Default window rolling up alittle slow. how do i lube the window tracks?
what kind of lube do you guys use? and what exactly do i have to lobe? NO i dont want to use KY jelly and no i dont want to lube my *** or anyones elses body parts!!!! its a serious question.
Old Aug 24, 2002 | 02:09 PM
uNF$@#!'s Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (Ch33se)
use silicon lubricant and apply it in the window track.
Old Aug 24, 2002 | 03:15 PM
kkim's Avatar
I used a teflon based spray called tri flow. I sprayed the tracks and anything that moved or pivots when I had the door panel off. works great now.
Old Aug 24, 2002 | 03:18 PM
Jason's Avatar
just take off the door panel, have some hot chick ride you in the front seat and then...........
Old Aug 24, 2002 | 04:07 PM
jond's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (George Knighton)
It's a known warranty issue. If you're under 50,000 miles, just get the dealer to do it.
Sweet. I didn't know that. Guess I'll be taking mine in.
Mine rolls up slow as ****.
Old Aug 24, 2002 | 04:57 PM
yoshi234's Avatar
I shoot brides
Default Re: window rolling up alittle slow. how do i lube the window tracks? (jond)
I applied silicon lube to no avail
yshi - whose window gets stuck near the top so he's taking 234 into the dealer to get it fixed before the warranty runs out
Old Aug 24, 2002 | 05:01 PM
330R's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (yoshi234)
had my driver's window done a week ago at the 30K mile service. the passenger side was good as new but the driver's was slower. i picked the car up and the window was screaming to the top
Old Aug 24, 2002 | 05:25 PM
wHOAlly's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (330R)
lithium grease is better, thicker
Old Aug 24, 2002 | 06:08 PM
Floyd's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (AkumaY)
Man, I got to get on this one right away. Both windows take forever to go up. Time to bust out the Helms again...
Old Aug 24, 2002 | 06:09 PM
Smitdog's Avatar
Perfectly said!!
Old Aug 24, 2002 | 06:28 PM
Mugen Mike's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (Smitdog)
And if your at 60K what do you suggest?
Old Aug 24, 2002 | 06:31 PM
Reid's Avatar
Global Moderator
Default Re: window rolling up alittle slow. how do i lube the window tracks? (mugenmike)
Old Jul 6, 2005 | 10:04 AM
#1151's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (Reid)
hahaah^^^ where do you apply it?..in the rubber part?..any pics from any one???
Old Jul 6, 2005 | 01:46 PM
No-Gi's Avatar
Default Re: window rolling up alittle slow. how do i lube the window tracks? (TodaFiend)
http://www.team-integra.net/se...D=596
Old Jul 6, 2005 | 01:50 PM
Viper8L488's Avatar
Whatever you do, do not use a petrolium based product. I have used Tri Flow in my window tracks. It helps temporarily, but petrolium eats rubber, so it will get worse over time.
Funnily enough, the best product I have used for long term window happiness is KY Jelly on the tip of a Q-tip.
Eighty-Nyne
Jun 6, 2009 04:04 PM
deerman2701
Nov 27, 2007 05:59 AM
aTrOcIoUs
Sep 11, 2007 08:17 PM
hott-nix
Apr 3, 2005 04:04 PM
0ptimus prime
Mar 16, 2004 09:37 AM
