B20/EK O2 sensor
Old Aug 3, 2009 | 05:18 PM
BokudenNYC's Avatar
Default B20/EK O2 sensor
I have a JDM B20 in my EK with an OBD1 ECU. Being that I have the obd2-obd1 conversion harness, I've been told that the only sensor I need is the downstream sensor. Should I be looking for a sensor from a Civic, Integra or a Crv. Or are they just all the same *****?
Old Aug 3, 2009 | 05:30 PM
raidacaipo's Avatar
Default Re: B20/EK O2 sensor
what the hell is a downstream sensor?
Old Aug 3, 2009 | 05:34 PM
BokudenNYC's Avatar
The one after the cat.....
Old Aug 3, 2009 | 05:38 PM
raidacaipo's Avatar
you mean secondary o2 sensor? no you dont need that.. your using a obd1 ecu. are there any check engine lights?
Old Aug 3, 2009 | 05:43 PM
BokudenNYC's Avatar
Yeah I have a CEL. I'm running ultra rich, I can smell it. I'm also burning gas like a ****. I assumed the lack of an O2 was the reason.
Old Aug 3, 2009 | 05:44 PM
punkdown's Avatar
If you don't already have one you will need to get a primary 4 wire O2 sensor for your chassis.
Old Aug 3, 2009 | 05:48 PM
BokudenNYC's Avatar
So I need the primary? Ok, but from what car?
Old Aug 3, 2009 | 05:54 PM
punkdown's Avatar
Sorry I guess I was being vague. Get one from an EX, that should work. I didn't know better when I needed one for my GSR swap so I got one for an integra. The plugs were the oppisite gender than what I needed so I had to make a adapter harness because I was trying to fix it at 2am.
Old Aug 3, 2009 | 05:58 PM
raidacaipo's Avatar
Do you know what cel code your getting? here read this: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
then come back and tell us your CEL code. It could be a primary o2 sensor which is before the cat converter. Its on the downpipe of your header
Old Aug 3, 2009 | 06:24 PM
BokudenNYC's Avatar
Yep, that's the one I'm missing....the one on the down pipe. I guess that's the primary, I thought that was the secondary. Like I said motor's a JDM B20, but I'm using my stock harness. So should be buying an O2 sensor for D-series or B-series? I'm trying to avoid plug fitment issues.
Old Aug 3, 2009 | 06:25 PM
BokudenNYC's Avatar
Originally Posted by punkdown
Get one from an EX
Ok cool, so the sensor from a D-Series EX will work? Thanks.
Old Aug 3, 2009 | 06:34 PM
raidacaipo's Avatar
any 96-00 civic o2 sensor will work. Im still using the one from my old single cam d16y7 motor.. any o2 sensor will work as long as it has 4 wires coming out of it.. usually its 2 black wires and 1 white and the other is green. But from any 92-95 civic, 94-01 integra will do
Old Aug 3, 2009 | 06:40 PM
BokudenNYC's Avatar
Thanks for the help.
Old Aug 4, 2009 | 01:43 AM
punkdown's Avatar
As long as he doesn't have an HX, those use a 5 wire O2.
Old Aug 4, 2009 | 07:29 AM
angel_i's Avatar
I think they are all the same as in the actual performance. The difference is in the wire length and connector. They should probably all work except for the 5 WIRE HX o2 Sensor.
RVMIRXZem1
Nov 25, 2018 07:51 PM
1slowcrx
Oct 3, 2006 08:56 PM
dkasakitis
Feb 14, 2003 08:04 AM
StyleTEG
Mar 22, 2002 04:24 AM
