B20/EK O2 sensor
I have a JDM B20 in my EK with an OBD1 ECU. Being that I have the obd2-obd1 conversion harness, I've been told that the only sensor I need is the downstream sensor. Should I be looking for a sensor from a Civic, Integra or a Crv. Or are they just all the same shite?
Re: B20/EK O2 sensor
what the hell is a downstream sensor?
The one after the cat.....
you mean secondary o2 sensor? no you dont need that.. your using a obd1 ecu. are there any check engine lights?
Yeah I have a CEL. I'm running ultra rich, I can smell it. I'm also burning gas like a mofo. I assumed the lack of an O2 was the reason.
If you don't already have one you will need to get a primary 4 wire O2 sensor for your chassis.
So I need the primary? Ok, but from what car?
Sorry I guess I was being vague. Get one from an EX, that should work. I didn't know better when I needed one for my GSR swap so I got one for an integra. The plugs were the oppisite gender than what I needed so I had to make a adapter harness because I was trying to fix it at 2am.
Originally Posted by BokudenNYC
(Post 39491685)
then come back and tell us your CEL code. It could be a primary o2 sensor which is before the cat converter. Its on the downpipe of your header |
Originally Posted by raidacaipo
(Post 39491917)
Originally Posted by punkdown
(Post 39491856)
Get one from an EX
any 96-00 civic o2 sensor will work. Im still using the one from my old single cam d16y7 motor.. any o2 sensor will work as long as it has 4 wires coming out of it.. usually its 2 black wires and 1 white and the other is green. But from any 92-95 civic, 94-01 integra will do
(Post 39492436)
(Post 39492436)
I think they are all the same as in the actual performance. The difference is in the wire length and connector. They should probably all work except for the 5 WIRE HX o2 Sensor.
