easiest way to remove rear mount
Theres should be only 3 bolts on the tranny that connects the mount, and 1 at the motor mount bracket, just take them off and slide it to the left , and it should come out fine.
i had to do the same thing. i took the motor mount that is connected to it with 17 and 18. once i got that off it was easy and lot of rooom to take it off.
If it's a GS-R with stock intake manifold, the rear mount T-bracket is a royal PITA, and so is the intake manifold. When I pulled my engine out, I just unbolted the bracket and let it fall out when I hoisted the engine up. After putting the engine back in, though, I spent at least 2 hours trying to get the bracket back in, and ended up crushing my heater core pipes in the process.
As for the mount itself, I think it would be extremely difficult to remove it w/ the engine and IM still in the car. I replaced mine with the IM removed, and that was even more of a PITA than it was to remove the whole engine.
i put one in my exs gsr, and even after i pulled the im it was still a pian, and i did the same thing patrickgsr94 did, cruched the heater coe pipes.
next time id rather just yank the damn motor.
AdamsAutoAdvice
May 25, 2025 05:21 PM
SiR Kid
May 12, 2003 05:02 PM
Civichatch972
Dec 8, 2002 11:42 AM
