Help with Cruise Control?
Old Aug 3, 2009 | 03:49 PM
moorevisual's Avatar
Default Help with Cruise Control?
when i got my 91 sedan a few months ago the cruise control was the only power feature that didn't work. i checked the fuse and it's good, so i'm wondering what would be the things to check to diagnose the problem.
thanks in advance-
Old Aug 3, 2009 | 04:10 PM
BiG ChOr!Zo's Avatar
Default Re: Help with Cruise Control?
im still trying to figure out where the fuse itself is...!!!
Old Aug 3, 2009 | 05:17 PM
black0hatch's Avatar
when mine stoped working there was a little rubber bumper on the clutch pedal that activated the clutch saftey switch and that little rubber thing came off so the switch wasnt getting pushed in. cruise control works with a bunch of saftey switches so check those theres 2 on the clutch and one on the brake pedals. some times the switches on the steering wheel get coroded inside and dont make a good conection. and check all the wireing too.
Old Aug 3, 2009 | 06:27 PM
thanks im gonna check all that tomorrow
Old Aug 3, 2009 | 06:55 PM
does it look similar to the blue piece that breaks off when your brake lights don't turn off
Old Aug 4, 2009 | 02:13 AM
im thinking the same thing..
Old Aug 4, 2009 | 04:25 PM
man that was exactly what it was! the little rubber piece that pushes the safety button had come off the clutch pedal, so i just put a screw in it for now to push the button and the cruise control works perfectly!
anyone know where to get the replacement rubber pieces besides the dealer or what they're actually called?
Old Aug 4, 2009 | 04:27 PM
im gonna go and check mine right now
Old Aug 4, 2009 | 04:54 PM
i tried every parts store for that little rubber piece none of them have it. best bet is the dealership it cant be that much but will probably be overpriced for what it is. i still got mine ghettoed up no problems.
Old Aug 4, 2009 | 05:04 PM
yea i just decided to put a nut and bolt on it, that way i dont have to worry about the rubber thing popping out again. thanks again!
Old Aug 4, 2009 | 05:05 PM
i just checked mine and it was missing so i just put a screw and a washer in it...i haven't test driven it yet but hopefully that solves the problem...!!!
Old Aug 4, 2009 | 05:06 PM
hope it works for you too, makes such a difference especially with all the highway driving i do
Old Aug 4, 2009 | 05:08 PM
aint that the truth...im sick and tired of pushing the gas pedal on my dpfi d15b2 when i drive long distances
Old Aug 4, 2009 | 05:09 PM
grog's Avatar
check the "my brake lights are always on " thread in the FAQS, in has some good alternatives for those plugs.
Old Jun 28, 2011 | 06:58 PM
Foxcow's Avatar
black0hatch, you are the man! I too was missing the rubber bumper. I put in a bolt with a nut to keep it from falling out and it works just like it used to.
The bolt I used:
I shaved the bolt head down on a bench grinder to prevent it from changing clutch pedal height:
If you press your clutch pedal in, you can see a hole where the rubber stopper used to be and the place where it pushes in the switch for activation:
I think this info ought to be stickied to help others searching for this same info.
anoble1
Jan 10, 2017 04:31 PM
bnewall1
Nov 19, 2013 12:01 AM
ed6inms
Nov 24, 2012 12:43 AM
Juan_Mitosis
Jun 19, 2008 11:13 PM
Dezmon
Mar 9, 2007 06:38 AM
