AC Compressor ?
Whats up guys... I need a write on how to install a ac compressor on a b series on a 93 4door civic???? I am using a sohc compressor with crv or del sol bracket still looking for it.. but i need a write up can someone help me out.. thanks
yes but i dont need to do anything with the pulley from the motors timing belt ****.. i tried doing loosing up the timing belt a while back and i couldnt tighten up again... thats why im asking.... plus does the does the year of the crv ac bracket matter.???? i am having a hard time finding it at my local junk or salvage yards... any other suggestions... and ebay doesnt have em??
http://www.hondaautomotiveparts.com/ has it for like $65 the last time I bought one from them. You need one from a 97-00 CRV. Don't believe auto/manual matters, but I got one from an automatic.
(EDIT: It's #1 in this picture, for $66.85: http://www.hondaautomotiveparts.com/...NE+MOUNTS+(AT))
I believe you'll have to remove the power steering belt to get at it, and probably also the power steering pump to get at all the bolts. It goes inside the power steering belt on the crank pulley. I believe that I reused the old AC belt from my D series, but I can't be 100% sure, as I had both D series and Integra belts at the time that I did it.
You should not have to do anything regarding the timing belt whatsoever, but you do need to set proper tension on your PS and AC belts when you put it back together. It shouldn't be that hard. The power steering pump has a sort of wingnut / set nut tension adjuster where the whole pump swings up and down. The AC has an adjustable idler pulley. To adjust tension, just move it in or out as needed.
