convert jdm/obd1 motor to obd2?
Old Aug 3, 2009 | 03:17 PM
killerpenguin21's Avatar
Default convert jdm/obd1 motor to obd2?
ok so let me start out by saying i know this can be done, i just want to verify that i have all my bases covered before i go buy a motor to use to only pass inspection.
1. my car is a 97 ex so it is obd2a i believe.
2. motor will be a b16a2
in order to use my factory obd2a harness...
-obd2 alternator
-obd2 dizzy
- ckf bypass as seen here http://technet.ff-squad.com/ckftrick.htm
-some way to trick the rear o2 into thinking there is a car installed (spark plug defoulers - anyone had any luck?)
my main question - what ecu? can i use an ecu from a 99-00 si? aka does obd2b work on obd2a?
Old Aug 3, 2009 | 03:25 PM
reyracerx's Avatar
Default Re: convert jdm/obd1 motor to obd2?
best ecu to use on that motor will be a p28 or p30 but you will need an obd2 to obd1 pigtail.
and not obd2a and obd2b harness are different.
Old Aug 3, 2009 | 03:31 PM
i cannot use an obd1 ecu, that will not allow me to pass inspection, it needs to be an obd2 ecu.
Old Aug 4, 2009 | 02:38 PM
reyracerx's Avatar
my bad dude i read the engine code wrong. i thought it was a jdm motor.
then to pass inspection you will need a p2t ecu which come off the em1. to make that work you will need an obd2b to obd2a conversion harness.
check ebaymotors, rewyre...
EkCoupeTurbo
May 13, 2013 05:16 PM
Killer Kham
Mar 19, 2012 08:37 AM
egbaby
Mar 1, 2008 06:52 AM
HondamanXxX
Aug 10, 2007 10:27 PM
hatchy
Mar 31, 2002 08:24 AM
