Couple Problems 1 thread
1. Squeeky doors (already tried to grease them up and it didnt even work)
2. Squeeky suspension.
3. AC sounds funny. Low rubbing sound when its on low to high.
4. Power steering sounds funny when turning at low speeds
Theres a couple of other things. Can I get some help please?
1. could be rubbing against the body panel when you open it
2. when?? always or just when you hit bumps?
3. is it on low or is it on high? rubbing sound, do you mean in the car or under the hood?
4. Have you checked the fluid?
also give us some info, is it an 81, 91, 01?? when do these things happen? what have you tried? if you greased the door where did you grease the lock or the hinge?
Thanks!
Thanks!
1. Its not hitting any body panel. It just squeeks when you open and close it.
2. When im driving in the morning or when its cold.
3. When I turn the AC on it makes like a low "UUURRRRRRRRRRR" sound. from low to high.
4. fluid levels are good. it makes a whiny sound when turning in low speeds.
its a 98. sorry thought i posted that earlier.
EGSSdreamer
Aug 11, 2004 09:49 AM
