post your backpurging setups!
Old Aug 3, 2009 | 01:12 PM
russianvr4's Avatar
OG Fabricator
Default post your backpurging setups!
i need some ideas on how to do a backpurge setup, any tips/pics?
thanks guys.
Old Aug 3, 2009 | 01:42 PM
ColtonVTECs's Avatar
Default Re: post your backpurging setups!
Interested in seeing pics.
Old Aug 3, 2009 | 02:03 PM
Frankenstein_VW's Avatar
I use a separate smaller argon tank, and a regulator. Then just run a feed line off of that into whatever you need to purge....
Old Aug 3, 2009 | 02:52 PM
BMCRace's Avatar
For plugs I love using steel wool. The tighter you pack it the better it seals, I usually double pack the side that has the line going in and half pack the side coming out so that it has a slow bleed down.
Old Aug 3, 2009 | 03:02 PM
downest's Avatar
I've been using this setup which I found on one of Weir's old posts. I just got the larger tank a couple of weeks ago and I want to get a new/good regulator for that one so I can use my M tank for the MIG and purging without switching stuff around.
Old Aug 3, 2009 | 05:27 PM
JDM KID 510's Avatar
Search.
Old Aug 3, 2009 | 05:50 PM
russianvr4's Avatar
OG Fabricator
thanks for your highly insightful and helpful post jackass.
Old Aug 3, 2009 | 07:42 PM
srmofo's Avatar
ive seen people use tin foil to cap the ends. its cheap and disposable....
or are you talking about where it comes off the tank?
Old Aug 3, 2009 | 08:10 PM
downest's Avatar
I thought he was talking about where it comes off the tank(s). Agreed on the foil, or rubber caps for things further away from the weld. I keep all the caps from radiators and intercoolers and stuff for that.
Old Aug 3, 2009 | 08:56 PM
tek_civic's Avatar
for charge piping and 2.5in exhaust work a half a coke can works great. you can use the top half for the entry and the bottom for the cap. I never really backpurge because all my welding is crap anyway haha, i just remember reading that in passing.
The only time i have ever back purged was when welding a fuel sump in a tank, and that was mainly because i washed it out a ton of times but was still paranoid about the explosive possabilities. Thats where the inert gas comes in
Old Aug 3, 2009 | 10:03 PM
ROTARY's Avatar
a similar thread with pictures was just started not long ago.
Old Aug 5, 2009 | 07:05 AM
downest's Avatar
For the other guys running a tee off a single tank, what do you run your gas at? I find that I need like 25-30 CFH to get good gas coverage that way, it's kind of hard to regulate the little valve thing by itself.
Old Aug 5, 2009 | 09:07 AM
russianvr4's Avatar
OG Fabricator
just got mine set up yesturday, was working pretty good at 15cfh. im tee'd off from my main tank.
Old Aug 5, 2009 | 09:20 AM
downest's Avatar
I run about 15cfh without the purge, I don't think that would be enough with some of the gas being diverted. I know on a seperate tank I'd run 5-10cfh for the purge so that leaves about half the gas for the torch if you do it that way. How are your welds coming out like that?
Old Aug 5, 2009 | 02:20 PM
.john.'s Avatar
I crank mine up to like 25 when purging and adjust the valve on the purge line until the sound of the gas from the torch is about the same as when it was 15. So when I'm welding the purge line is barely running but between welds it fills the tube back up.
Old Aug 5, 2009 | 05:02 PM
russianvr4's Avatar
OG Fabricator
how fast do you guys go through argon when backpurging?
Old Aug 5, 2009 | 08:38 PM
frostyrb's Avatar
Check arc-zone.com. You can get some ideas from them cause they sell a variety of backpuring kits. Hope this will help you some.
wade
Welding / Fabrication
69
May 16, 2012 11:45 AM
downest
May 5, 2009 12:14 PM
FullRaceHonda
Feb 21, 2007 10:08 PM
RACEPAK
Dec 5, 2006 06:33 AM
1 2 NV
27
Nov 12, 2002 05:37 PM
