wheel moving back and forth
ok, from front to back the wheel only moves like 1" but its toward my door and then towards the bumper.... is that just the radius rod bushings or is somthin else wrong? it was doing this before so i replaced wheel bearings, struts (illuminas), upper control arms and it didint help at all, im also gettin wheel hop under accel. im about to do a poly kit but i dont know what comes in the kit for 91 accords, cant find an item list- any help would be great, thanks guys
try crawling under there while someone else moves the wheel back and forth. look to see what is moving in a direction it shouldn't. i guess that's really the only help i can give without being able to look myself...
Stock suspension isn't really meant for the track. Your going to get wheel hop until you upgrade the suspension bushings or upgrade to a full race torsion bar setup. Now that being said. If you can physically move your wheel & hub assembly by hand 1" east to west. You are suffering from more than just wheel hop and sloppy bushings. You need to have your suspension checked out.
Like hondamark35 mentioned get under there are see what's moving. With 1" of travel it shouldn't be hard to spot the culprit.
90H22
Jan 28, 2003 09:47 AM
Mr. Vapor
Dec 5, 2002 05:29 PM
