pilot bearing
Old Aug 3, 2009 | 09:53 AM
dacrxguy's Avatar
Default pilot bearing
i was wondering if anyone has found an alternative to a crx with a d series tranny pilot bearing. the one i got in my kit slides off even after being hammered on.
Old Aug 3, 2009 | 10:22 AM
dephtone's Avatar
Default Re: pilot bearing
You mean comes out from inside the flywheel?
Old Aug 3, 2009 | 02:03 PM
sanimalp's Avatar
$cat /dev/urandom
there should be a lip inside the race of the pilot bearing that retains the bearing when the flywheel is tightened down to the crank. The bearing should not come out as long as that lip is there. If the lip isnt there, then you need a new flywheel because yours is damaged.
Old Aug 3, 2009 | 05:24 PM
black0hatch's Avatar
did the old bearing just fall out too or did you have to hammer it out? ive never had a pilot bearing that wasnt a tight fit.
Old Aug 3, 2009 | 05:32 PM
johnnyonth3spot's Avatar
I have a fadanza 6 1/2 flywheel and the bearing I got for it had a slip fit like yours I put locktite on it to hold it in place while i installed the transmission and mine has given me 0 problems for over a year. I was worried about it though
Old Aug 3, 2009 | 08:43 PM
dacrxguy's Avatar
I did this but i used sleeve holder from napa worked but i still need to find out if it is ok since i am doing auto to manual swap. Tomorrow i will install axels and finish it up
ps when i pull on the realese lever it is very soft is this normal on a cable trans?
Old Aug 3, 2009 | 09:14 PM
D16SiHatch's Avatar
it should move a little bit very easily until the throwout bearing actually hits the fingers on the pressure plate.
Old Aug 3, 2009 | 09:37 PM
dacrxguy's Avatar
its a oem replacement cluth and it mover freely for about 3mm and then its the same sogtness throuhgt the whole thing
when i installed the presure plate it looked flat well only way to find out is to try it
Dxs
Transmission & Drivetrain
Apr 10, 2015 11:59 PM
rick_rabies
Jun 12, 2013 01:33 PM
HondaRexBoi
Apr 3, 2007 05:36 PM
1fastVX
Aug 22, 2002 05:43 PM
