Idle problem. Plz help
Old Aug 2, 2009 | 11:15 PM
hatch_kidb18b1's Avatar
Default Idle problem. Plz help
Hey guys so I have a idle problem. When at idle it revs up to about 1500 then goes down then up and down so on and so on. I don't know what it could be I checked all the vacum lines and could not find a leak. Can anyone help? Thanks guys
Old Aug 3, 2009 | 06:06 AM
dephtone's Avatar
Default Re: Idle problem. Plz help
IACV is usually the culprit, or low antifreeze or air in the coolant system.
If you unplug the IACV does it give it a fast idle that fluctuates only a ~2-300 rpm? If it stalls out, you know your IACV is bad.
Old Aug 3, 2009 | 07:59 AM
.Manny.'s Avatar
Touching My Member
take off the FITV that is located under the throttle body, take off the two 8mm bolts and cover plate on the rear, screw the little valve all the way in until it stops and you'll be a-ok.
Old Aug 3, 2009 | 03:53 PM
724chris's Avatar
im having this problem too. i cleaned my ivac and its still doing it. it only happens after its warmed up tho
Old Aug 3, 2009 | 08:20 PM
D16SiHatch's Avatar
its 3 bolts, the iacv is 2 lol
try like he said and clean her out
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
and do the same with the iacv
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old Aug 4, 2009 | 05:27 AM
.Manny.'s Avatar
Touching My Member
lol, i meant the little bolts holding down the plate. I usually pull the whole TB off. 10 min job if its not messy in there
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
julianbc2
May 12, 2009 01:33 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
civc_tt
Jul 30, 2006 11:00 AM
The Specialist
May 6, 2004 12:20 PM
