Suspension & Brakes Theory, alignment, spring rates....
Quick question: Allignment
Old Aug 2, 2009 | 02:20 PM
JasonYo's Avatar
Default Quick question: Allignment
So I had my car alligned at the height I set it at with my ground controls, but the other day I raised it a little bit (about 1 inch) but then I put it back down exactly where I had it before.
Since I put the car back to the height it was when I got an allignment would that mean everything is fine?
And another thing, If i raise or lower the car just a little bit, like an inch or a few turns on the coilovers would that mean I need to get the toe adjusted again?
Any help is appreciated!
Old Aug 2, 2009 | 04:21 PM
racebum's Avatar
Default Re: Quick question: Allignment
if you go up toe goes in, down it goes out. you could always set the toe out 1/8th or so up front and at zero out back. this way if you raise the car the front works toward zero as you go up and the rear toe goes in. easy way to split the difference.
APAem1
Suspension & Brakes
Feb 11, 2011 03:02 PM
NHswaps13203
Suspension & Brakes
Apr 27, 2008 11:23 AM
DANgerous
Oct 23, 2004 12:31 PM
SD_EM1
Jul 16, 2003 04:56 PM
Volcom
Mar 3, 2002 07:10 PM
