94-96 EL gauge harness swap = no more JDM fogs
Old Aug 2, 2009 | 01:53 PM
saikou's Avatar
Default 94-96 EL gauge harness swap = no more JDM fogs
Just finished up swapping a 94-96 EL gauge harness into my 93 Si for the EL gauge conversion. On my old harness, I did the paper clip trick to have my JDM fogs come on whenever my headlights were on. Now that the 94-96 harness doesn't have the fog light connector behind the tweeter, my fogs obviously don't work.
I would like to have the fogs remain to only come on whenever I switch to my headlights. Without having to install an aftermarket/OEM switch anywhere... unless I absolutely have to. Anyone have any insight on the situation?
Old Aug 2, 2009 | 04:21 PM
TheCivicMafia's Avatar
Default Re: 94-96 EL gauge harness swap = no more JDM fogs
Never mind. Sorry
Old Aug 2, 2009 | 04:52 PM
meanshyguy's Avatar
What we did on my brother's was ran the two wires on each foglight to the low beams, but that's not always to proper way to do it, it worked fine though.
Old Aug 2, 2009 | 05:12 PM
saikou's Avatar
Thanks for the suggestion!
But I don't think I want to go that route. Here's a post I found after searching a bit:
Originally Posted by crdcz03
i just fixed this problem yesterday after not having working fogs for like 2 months.
i used the EL harness and sacrificed my fogs for a lil while for easy install of the cluster lol.
yesterday me and a buddy finally had time to work on it and heres what we did:
look under the dash for your foglight relay. cut the blue/red wire and the red/green wire (i think all the others are red/yellow IIRC). add some wire to those to wires to get to the switch. then, if you're looking at the switch from the front, i think its the two pins farthest to the right. butt connector your new wires to the old ones (if you saved your plug from your old harness like i did) and the fogs should work.
Basically, I believe I need to extend those 2 wires from the relay and butt connect them to the old fog light plug from my old gauge harness. The old fog harness (behind tweeter) has 6 wires off of it (red/black, solid red, solid black, red/green, solid orange, red/yellow). So, I'm not sure what 2 farthest right wires he's talking about. I also need to know if this method will still work with the paper clip in the harness trick so the fogs only come on with the headlights. I sent him a message, so hopefully he replies back and I'll have an answer.
Old Aug 2, 2009 | 06:53 PM
cruizer's Avatar
damn i had the exact same issue and that was the only thread i could find.....it was a little confusing to me too....let us know when u find a solution caused i want mine wired like how you want it....right now i have to use the switch turn the fogs on and off
Old Aug 2, 2009 | 09:07 PM
minilogoguy18's Avatar
Get your old harness and trace the wires for the fogs back to the plug on the driver side. Take the plug apart, pull the wires and pins and then plug them in the new harness in the same slots you took them. That's what I did, it's pretty easy.
Old Aug 2, 2009 | 09:18 PM
saikou's Avatar
What?
I don't have a new harness where there is a fog light plug. Like the old 92-93 gauge harnesses, the 94-96 EL gauge harness does not have the tweeter fog light switch harness. Could you explain further?
Old Aug 2, 2009 | 09:42 PM
You can take the wires for the switch from your old 93 Si harness and plug the pins into the new 94+ harness and then you can wire up the switch.
Old Aug 2, 2009 | 11:09 PM
meanshyguy's Avatar
I didn't have this problem since I did the wire-re-routing technique with my
EL on my 93si
Old Aug 3, 2009 | 06:55 AM
cruizer's Avatar
Originally Posted by saikou
What?
I think he means save your old 92-93 dash harness, trace the fog light portion of that harness and de-pin it. After you de-pin it just remember where each wire came from and plug them back in on the 94-96 dash harness.
Old Aug 3, 2009 | 07:00 AM
Exactly, I didn't think I did a too bad of job trying to explain. =/
Old Aug 3, 2009 | 08:16 PM
saikou's Avatar
Lol, I'm sorry dude... for some reason I was thinking you meant to de-pin the wires from the green plug for the fog light switch (the end that plugs into the on/off switch). I was saying to myself, "what the hell am I going to do with the plug end with no wires attached to it?" You meant to de-pin the wires for the fogs from the gray plug near the kick panel fuse box and pin them into the EL gauge harness in the same spots. Just took me a while.
Hopefully this thread helps out anyone needing to get their fogs wired back up after an EL gauge harness swap. Thanks guys.
singlecamslamed
Feb 21, 2011 07:08 PM
DavidHLX
Honda Civic (2006 - 2015)
12
Jan 9, 2009 10:55 AM
H22Ej1
26
Mar 12, 2008 06:56 PM
JDMSpoonType-R
Jun 23, 2005 06:50 PM
GiFF
Oct 17, 2001 12:25 AM
