Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Fogs
Old Jan 7, 2009 | 04:54 PM
DavidHLX's Avatar
Default Fogs
Ok I'm having a bit of trouble with the fogs. I purchased some fogs awhile back and I'm planning on putting them on this weekend or so. But the problem is that most of members have 3 different wires (Sub Harness, Switch Harness, and the Fog Light Harness). The one I currently have is the Switch Harness and the Fog Light harness(missing the SUB harness). Now my first question is, can I hook up my fogs with just those 2 harness(Switch Harness and Fog Light Harness)? WIll it reach in my seadan? If not can I purchase the OEM SUB HARNESS(from honda) and connect them to the Fog Light harness and Switch Harness( The ones i currently have)?
Old Jan 8, 2009 | 01:13 AM
DavidHLX's Avatar
Default Re: Fogs
anyone?
Old Jan 8, 2009 | 05:54 AM
Zeusone's Avatar
Default Re: Fogs
the OEM honda harness will work fine. good thing about that is now you'll have the fog light indicator on the dash.
Old Jan 8, 2009 | 09:24 AM
DavidHLX's Avatar
Default Re: Fogs
So the connections should be the same? From the Fog LIght Wires to the OEM SUB harness to the Dash Switch wire?
Old Jan 8, 2009 | 09:54 AM
Zeusone's Avatar
Default Re: Fogs
when you say switch harness, how many connections does it have on it? i think its only two harness' that you need. one is to connect the fogs to the vehicle harness by the windshield wiper resovoir and the other connects everything under the dash.
Old Jan 8, 2009 | 02:27 PM
DavidHLX's Avatar
Default Re: Fogs
http://www.collegehillshonda.com/ins...oglightkit.pdf
I see that there is 3 different wires, I have only 2. Switch and Fog light wire...looks like I'm missing the sub harness. Was wondering if i can just use the 2 wires i have or should I order the sub harness from honda and use all three wires, would it still work?
Old Jan 8, 2009 | 02:35 PM
Zeusone's Avatar
Default Re: Fogs
OEm fogs?
Old Jan 8, 2009 | 02:43 PM
DavidHLX's Avatar
Default Re: Fogs
I got Ebay ones but only came with 2 wires but I see that the OEM ones needs 3 wires
Old Jan 8, 2009 | 03:20 PM
Zeusone's Avatar
Default Re: Fogs
and yours came with the stalk button from the link? it doesnt have a push button? you should only have 2 harness'
Old Jan 8, 2009 | 03:22 PM
DavidHLX's Avatar
Default Re: Fogs
I just have a push button. So if I had the Stalk i will need 3 wires? If I have the push button I
just need 2 wires?
Old Jan 9, 2009 | 12:23 AM
Zeusone's Avatar
Default Re: Fogs
for the button and stalk it only comes with two harness'.
Old Jan 9, 2009 | 12:28 AM
DavidHLX's Avatar
Default Re: Fogs
So it should work for my sedan? Also another question..with only 2 wires can it reach all the way to the dash?
Old Jan 9, 2009 | 10:55 AM
Zeusone's Avatar
Default Re: Fogs
heres a diy. you can follow this. http://www.8thcivic.com/forums/light...-oem-fogs.html
accordinglyevil
Honda Civic (2001 - 2005)
May 20, 2011 08:32 AM
nacnud_z24
Jun 17, 2008 05:24 PM
LsHoney84
Dec 20, 2005 06:11 AM
