b16b but no vtec
Old Aug 2, 2009 | 11:43 AM
STATek9's Avatar
Default b16b but no vtec
i have a 97 hatch with a ctr swap. but i have no vtec. back when i had the ctr in my em1 i was only able to hit vtec on a p06 ecu with a chip. but the ctr ecu that hmotorsonline supplied me with in accordence with the motor will not allow me to hit vtec. it didnt work in the em1 and now it doesnt work in my hatch. since i have swapped the ctr into the hatch i changed the wiring harness back to the ctr harness that came with the motor when i got it. and now i cant even hit vtec on the chipped p06. my speed sensor is hooked up so is the rev senser. i have an o2 senser on the header but i dont have one on the test pipe but i dont think that should matter but idk about the jdm computers . i do have a check engine light at the moment. but in my em1 when i had my b16a2 in there i had a check engine light the whole time and still was able to hit vtec all day long
Old Aug 2, 2009 | 11:48 AM
reyracerx's Avatar
Default Re: b16b but no vtec
what trim is your civic? dx or ex?
if its dx you gotta wire up the vtec because even with a vtec ecu it wont pop since the dx harness does not have the wiring for the vtec solenoid not vtec pressure switch.
Old Aug 2, 2009 | 11:50 AM
STATek9's Avatar
its a dx but i have swapped the under dash harness with one from an em1
Old Aug 2, 2009 | 11:51 AM
slowhatchcali's Avatar
check your CEL there in lies your answer for no vtec...
Old Aug 2, 2009 | 11:53 AM
STATek9's Avatar
whats cel?
Old Aug 2, 2009 | 11:59 AM
Originally Posted by STATek9
whats cel?
check engine light
Old Aug 2, 2009 | 12:19 PM
reyracerx's Avatar
you underdash harness has nothing to do with the vtec wiring.
like slowhatchcali said check your check engine light codes. you will need an obd2 scanner. you can try to see if autozone or kragen still rent them out or buy one.
Old Aug 2, 2009 | 12:24 PM
slomofo's Avatar
GDD Member
OBDII Scanners don't read JDM ECUs.
He needs to do it the old fashioned way by using a paperclip in the jumper, then counting the flashes.
Old Aug 2, 2009 | 12:26 PM
STATek9's Avatar
yeah i got a obd2 reader and yeah it dont read jdm computers so how do you do the paper clip trick
Old Aug 2, 2009 | 12:28 PM
in the passenger side for a two pin connector, i think its a green plug, not too sure on ek's, but its not hard to spot... once you find that clip get a paper clip and jump the two pins then read the code
Old Aug 2, 2009 | 12:35 PM
STATek9's Avatar
can you explain to me how to read them its been awile since i have done it
Old Aug 2, 2009 | 12:40 PM
sure.. you jump it, switch the ignition to the "ON" position....
it'll start throwing the codes(light blinking) ... each blink has a value 1 or 10.. a short blink equals 1 and a long blink equals 10.. so say you get one long blink and 7 short ones with no pauses in between, thats code 17(vss) ... if you have multiple codes there will be a pause in between codes untill all the codes are displayed then it'll it do it over again ...
Old Aug 2, 2009 | 12:46 PM
STATek9's Avatar
ok i cant find the two pin connecter your talking about
Old Aug 2, 2009 | 12:49 PM
STATek9's Avatar
like where is it at on the passenger side. i got all my ac **** gutted by the way. the whole box and everything
Old Aug 2, 2009 | 12:51 PM
try this http://www.2carpros.com/forum/2000-h...-vt257973.html
Old Aug 2, 2009 | 01:16 PM
STATek9's Avatar
thanks so its throwin code 7 which is the tps sensor which might be why my car idles at 2500. and the second one is 41 which is primary oxygen sensor heater wtf is that?
Old Aug 2, 2009 | 01:58 PM
STATek9's Avatar
well thanks to you guys i finally have true vtec on a ctr ecu. it was the tps sensor which i just took one off my old ls/vtec that i got sittin in the garage. this **** is nasty now thanks for all your help
Old Aug 2, 2009 | 02:46 PM
glad you got it figured out!!
typeRcoupe32
Jun 27, 2008 04:32 AM
crxman22
Jul 22, 2005 02:35 PM
V8K1LLER
22
Jan 25, 2005 08:39 PM
boostng r
Nov 7, 2004 08:47 PM
rbf351
May 7, 2002 10:47 AM
