Jdm B18c and USDM B18c , Something i found out today
Old Aug 2, 2009 | 10:47 AM
Ej8_KiD's Avatar
Default Jdm B18c and USDM B18c , Something i found out today
So today while i was replacing my Timing belt i noticed that the lower TB cover on my jdm b18c was different from the one i had laying around which was a usdm one, Even the part number is different
usdm part # 11810-P72Y-A0
jdm part # 11811-P3F-0000
Jdm cover
Usdm cover
See the diferences?
Old Aug 2, 2009 | 11:43 AM
Ruben19's Avatar
Default Re: Jdm B18c and USDM B18c , Something i found out today
kinda looks like a single cam cover
Old Aug 2, 2009 | 12:44 PM
BryanM.'s Avatar
Resident Gearhead
It looks like both have the upper right mount hole in the same spot, but the lower mount holes are in slightly different locations and the USDM one has a third hole.
Does that mean the blocks are cast differently? Have you checked to see if they compatable from one block to the other?
Obviously the gaskets are different. Must be hard to get one for the JDM cover, or even the cover itself.
Old Aug 2, 2009 | 03:05 PM
Garage 808 Hatch's Avatar
looks like OBD-1 vs OBD-2
Old Aug 2, 2009 | 03:23 PM
Turbo B18C EJ6's Avatar
jdm motors didnt come with a crank sensor like the usdm motors do. and like said above the usdm is proberly obd2.
Records
Feb 27, 2012 03:19 PM
97civicB18C
Apr 27, 2006 05:38 PM
Hilary_duff
Feb 23, 2005 08:43 AM
muskrat hatch
34
May 7, 2004 01:58 PM
pacifico
Feb 11, 2004 10:52 AM
