stuck throttle cable, please help cars idling at 3k!
Old Jul 31, 2009 | 09:42 PM
NAallthewayEM1's Avatar
Icon6 stuck throttle cable, please help cars idling at 3k!
as the title says, my throttle cable is stuck on my ls/vtec and I was wondering if anyone has any ideas on how to get it unstuck.
Old Jul 31, 2009 | 09:44 PM
sde780's Avatar
Default Re: stuck throttle cable, please help cars idling at 3k!
PB Blast + jiggle it around is your throttle cable too tight?
Old Jul 31, 2009 | 09:51 PM
alright thanks man, I'll try that.
no I've never had a problem with it before, car actually idles low normally and was gonna adjust the idle soon, but now this is happening.
Old Jul 31, 2009 | 09:56 PM
Former User's Avatar
Is the problem the throttle cable or a stuck open throttle plate?
Old Jul 31, 2009 | 10:01 PM
I'm pretty sure it's the throttle cable, I started the car and let it sit for a few minutes. after a few minutes of it sitting at 3k, I popped the hood and pushed the thing the cable is connected to (the throttle plate?) to the left and it went back to idling normally.
I'm not really sure to tell you the truth.
Old Jul 31, 2009 | 10:09 PM
Disconnect the throttle cable from the throttle body. Now turn the throttle plate from where the cable was attached to see whether, after turning the plate to WOT, it returns freely and effortlessly to the fully closed throttle position. If the plate sticks open, cleaning the throttle body should solve the problem.
Old Jul 31, 2009 | 10:14 PM
alright, thanks a lot man. I'll try that in the AM. if it's not the plate sticking, is there anything else I can do?
Old Jul 31, 2009 | 10:19 PM
Leave the cable detached from the throttle body and push the accelerator pedal up and down to see if it fails to move freely. If so, try to figure out where the problem is, the cable or pedal.
Old Aug 1, 2009 | 01:44 AM
fastrxu's Avatar
Why don't u clean ur tb plate anyways it's like 2 bucks for some tb cleaner
Old Aug 1, 2009 | 07:02 AM
92ehatch's Avatar
i have had the boot on the throttle cable move under the cable holder thing on the throttle body and cause it to stick open (sorry i forgot what the thing is called lol)
anyways, make sure that boot isnt slid under that.
and do what everyone else said
Old Aug 1, 2009 | 07:15 PM
sorry it took so long to get back to this. I figured out what was wrong, and when I traced the cable back to the pedal, the plug that goes into the firewall came out and ended up stretching the cable out. put the plug back in and car idles fine now.
thanks for the advice everyone.
Old Aug 1, 2009 | 08:26 PM
sde780's Avatar
i had to drive around with a stuck throttle cable for 1 day, revving to 4k in neutral by itself was not fun
Old Aug 1, 2009 | 08:41 PM
that_boy_sammy's Avatar
your gunna need 2 people for that one.
fast+forward
Sep 27, 2006 04:44 PM
vinuneuro
Feb 26, 2006 10:14 PM
rolledthatho
Sep 9, 2005 10:29 AM
clean
Jan 21, 2002 06:01 PM
