rattle/clicking sound from tranny
ef hatch,my cars motor is a d15b7, so at idle or when the clutch is not in there is a clicking rattleing noise coming from the tranny area, but when i push the clutch in the noise goes away. by any chance is this a throw out bearing going bad? my from wit a da integra has this same noise issue and we can't figure out what it could be. any ideas? thanks
really? you still have the noise and after you fixed the throw out bearing it was still there?!?! damn im having a hard time tryin to figure this out. this cars just my daily and im tryin to keep it in good shape. will post video later
It is the input shat bearing. If it was the throw out bearing it would make the noise when you pressed the clutch in not when you release it. I have the same problem just have not made the attempt to tear apart the tranny. Here is a DIY for you https://honda-tech.com/forums/tech-misc-15/diy-how-take-off-transmission-inspect-input-shaft-bearing-596878/ best of luck here is one with pics http://members.lycos.co.uk/pies/
It is the input shat bearing. If it was the throw out bearing it would make the noise when you pressed the clutch in not when you release it. I have the same problem just have not made the attempt to tear apart the tranny. Here is a DIY for you https://honda-tech.com/forums/showthread.php?t=596878 best of luck here is one with pics http://members.lycos.co.uk/pies/
I dont know really. I have been driving on mine for about a month without fixing it. But with anything if there is a small problem now and you wait it can turn to a big problem later.
Emshhh
11
Feb 2, 2005 11:10 PM
sohcvtec66
Dec 12, 2003 12:40 AM
