Keyless Entry Stopped Working!
My car stopped starting in a weird way. When i turned the ignition on, nothing turned on. I recharged the battery and it started. The next day my car died and nothing worked, my starter wouldn't turn over even with a jump. It ended getting towed to a shop. I have a new starter now but my keyless entry doesn't work. They didn't bother fixing it even though I told em'. I thought they were idiots anyway.
My battery is almost 3yo and puts out 12.6 volts.
My windows work
I checked all my fuses
I replaced my remote battery.
I need some advice. Ill be lookin up info in the mean time.
My windows work
My car is a 99ej8. I don't have any sort of deck in my center console. I tried anyway. No worky. I wonder if there is a way to program the remote without using the valet button. Thx for the info
1. No luck. My power windows work but the locks don't. I took my car to an eshop and they said it could take about 3 hours worth of work to figure it out($300). They look intimidated too, lol. F that ****. Any advice
2. I noticed that some of the harnesses in the door panel have brown marks on them. I wonder if they're fried. I'll update
3. How do you check for a bad ground?
I eventually fixed the problem which was: corrosion comming from the positive battery terminal. I replaced both of the cables running from the + terminal. One went to the starter, the other went to the fuse box.
cvanderhoef
Apr 26, 2015 07:45 AM
watacivic
13
Jun 27, 2007 11:28 AM
