whats wrong with my car. need some input
Old Jul 31, 2009 | 12:45 PM
jdm_integra96's Avatar
Default whats wrong with my car. need some input
well recently my speedometer just quit working on me. i have swap out the vss and bought a new gauge cluster and it still didn't work. now i'm lost as to what else can cause the speedometer to stop working. i have a ls/v in the car if that helps.
Old Jul 31, 2009 | 12:47 PM
raidacaipo's Avatar
Default Re: whats wrong with my car. need some input
easy my friend. Fuse #15 is out.. check that fuse under your steering wheel. I believe its a 10
Old Jul 31, 2009 | 01:26 PM
thanks for the input but i just checked the fuse and replaced it and still no go..
Old Jul 31, 2009 | 01:40 PM
97ej6dx's Avatar
hmm i had a problem like that and it ended up being my alternator i would make sure that is working correctly otherwise your spedo plug may have become damaged
Old Jul 31, 2009 | 02:18 PM
raidacaipo's Avatar
so your positive you replaced fuse #15??? hrmmm.. then like 97ej6dx stated.. your speedo plug or vss plug may be malfunctioning.. try cleaning it or checking the wires
Old Jul 31, 2009 | 03:04 PM
yep im possitive i replaced the fuse..yea well i'm going to have to check out the vss wiring and speedo cable when the engine is cool.
Old Jul 31, 2009 | 03:32 PM
slow96lude's Avatar
My ecu fuse under the hood was blown and caused this too in my prelude. Just a thought
Old Jul 31, 2009 | 03:46 PM
slowhatchcali's Avatar
mine started doing that.. but me its the cluster, i hit the cluster and it comes back on lol i have a new cluster though.. did you replace the vss sensor with a new or a used one? chances can be that its also bad if thats your problem, unlikely but feasible...
Old Aug 2, 2009 | 05:08 PM
well i swapped the vss from my brother's b20 and it didn't work and when i threw his back into his car it works so i'm assuming it's not the vss unless it's the harness.
Old Aug 2, 2009 | 08:06 PM
civicgsr499's Avatar
check the vss plug. mine was all chewed out n thats y it wasnt workin. cut one off a friends harness n everythings good
Old Aug 2, 2009 | 08:53 PM
Jimster480's Avatar
check inside the plug if water got in there. This happened to me 2 times last week with all the damn rain. Water got in the plug and just grounded all the terminals together reading 0 all the time.
Blaze45
Apr 11, 2018 12:51 PM
parisz47
Apr 11, 2017 05:02 AM
agustintorre
Sep 14, 2012 06:55 PM
88aeFC3S
Aug 4, 2008 12:41 PM
9sihatch3
Jul 31, 2006 10:51 AM
