How would I identify........
i was given what i was told a d16z6 OR y7 (whatever that is, if someone could clear up what it is) head, it has a vtec solenoid attached to it, i would love to know if there are markings on it, or serial numbers i could post up or a way to make sure what it is.
Also i was given a transmission that i was told was out of a 96-00 EX coupe, so also, want to know how to identify that via same way , serial numbers or markings.
Also , if it is a z6 head, or y8/7 head, what would i need to do to put that head on my d15b8...
And what would i need to do, to put that tranny up to my d15b8, do i need the shift linkage that came with that tranny? or can i use mine and its a straight drop in, do i need the clutch setup? or can i use my clutch and flywheel.
Lastly, do i need to change anything around for that tranny, anything at all?
Answer those in that order please!
Thanks!
- Paul
Thanks!
- Paul
92 Si D16Z6 5sp P08-2
93 Si D16Z6 5sp P08-4
93 EX D16Z6 5spd P08-4
93 EX D16Z6 5sp P08-3
94 EX D16z6 5 spd P08-2
94 Si D16z6 5sp P08-3
94 EX D16Z6 5sp P08-4
94 SI D16z6 5sp P08-5
95 EX D16Z6 Auto P08-2
Edit (found my y7 info):
If I recall correctly all d16y7 heads start with Y2F-HA-xx.
Everything should bolt up and work just fine, if I have given any incorrect information, please feel free to correct me.
well, im not sure where to find these markings, on the front of my head it says something of the sort of p2j7, or...p27 or something...and the trans has NO markings anywhere
i did, and found where they are supposed to be, it says YSK1, which i think is a prelude trans, since the parts came from inside a friends 91 prelude parts car, he uses it for storage haha.... there is no stamp near the drain plug exept for YSK in a circle , and a 1 near it. wonder what that means
gdub604
Transmission & Drivetrain
Jun 12, 2014 05:07 PM
from a 90si i believe
