Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how is it called?...
Old Jul 30, 2009 | 01:43 PM
blink_977's Avatar
Default how is it called?...
hey everybody, i am looking for thing that hooks up instead of second oxygen sensor and makes ecu think the sensor is ok! want to find on ebay and can't remember how is it called? i want to remove cat and secondary oxygen sensor.
Old Jul 30, 2009 | 02:45 PM
ChargedSI's Avatar
Default Re: how is it called?...
I don't think you actually eliminate the 2nd O2 sensor, you only add a fitting that changes the air dynamics of the exhaust as it passes by the 2nd sensor, hence tricking the ECU. Someone will correct me if I am wrong. A better option is to just get Flashpro and tune the motor properly to run without a CAT. The engine ECU is not flashed from the factory to run without a cat or 2, O2 sensors. I believe most people who did what you are asking, did so to run a header. Before Flashpro, people who wanted to run a header had no choice.
In my opinion, taking a shortcut like this will likely cause you more greif than you want.
To actually answer your question, I think what you are talking about is a de-fouler.
Old Jul 30, 2009 | 02:51 PM
KlickityClack07's Avatar
Its called a defowler, but i believe ChargedSi is right. Get COBB Ap, and run the stg2 map witch deletes the code all together.
Old Jul 30, 2009 | 04:14 PM
i-VTEC_DOHC's Avatar
here is what you need
http://jhpusa.com/store/pc/viewPrd.a...idproduct=2952
Old Jul 30, 2009 | 05:54 PM
Kidnkorner's Avatar
o2 simulator, they are becoming harder to find due to the EPA cracking down on retailers who sell them.
http://fasttoys.net/shop/product_inf...roducts_id=375
You might be lucky to find a vendor outside of the US who is not bound by US law.
Old Jul 30, 2009 | 10:58 PM
blink_977's Avatar
thanks!
PJHennessy203
Jan 19, 2016 05:10 PM
13link EG
Oct 13, 2004 09:18 PM
Redsun
Oct 1, 2004 02:46 PM
drunknmunkypow
Feb 1, 2004 05:21 PM
DevilS2000F
Honda S2000
Jul 6, 2002 11:46 AM
